I’m working on a lib and I use pre extraScript
features. On this script I select the good HAL allowing it to compile for the good target.
Lib users should be able to develop their own HAL easily by adding a folder.
But I have some specific HAL that needs some additional scripting operations. In this case I would like to call this additional script from the HAL folder on the pre_extraScript.
I’m importing this specific script but the Import("env")
line create an error :
NameError: name 'Import' is not defined:
I’m not a good python dev, Do you have any insight about it?
