I'm unable to compile
Hi I’m new and I can’t compile my code
 *  The terminal process "C:\Users\gabri\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
 *  Executing task: C:\Users\gabri\.platformio\penv\Scripts\platformio.exe run
PLATFORM: Espressif 32 (6.7.0) > Espressif ESP32 Dev Module
 - framework-arduinoespressif32 @ 3.20016.0 (2.0.16)
Found 52 compatible libraries
|-- SPI @ 2.0.0
|-- OTAdrive @ 1.1.30
|-- TinyGSM @ 0.11.7
|-- PubSubClient @ 2.8.0
|-- ModbusMaster @ 2.0.1
|-- RTClib @ 2.1.4
|-- ArduinoJson @ 7.0.4
|-- Alarm
|-- Farm
|-- FileManager
|-- LocalClock
|-- MQTTComponent
|-- Network
|-- OtaFirmwareUpdate
|-- Relay
|-- SimA7672
|-- StoringVariables
|-- Wifisetup
Compiling .pio\build\esp32dev\src\main.cpp.o
In file included from C:/Users/gabri/.platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:24,
                 from src/main.cpp:1:
c:\users\gabri\.platformio\packages\toolchain-xtensa-esp32\lib\gcc\xtensa-esp32-elf\8.4.0\include\stdint.h:9:16: fatal error: stdint.h: No such file or directory
* Looking for stdint.h dependency? Check our library registry!
* CLI  > platformio lib search "header:stdint.h"
* Web  > https://registry.platformio.org/search?q=header:stdint.h
 # include_next <stdint.h>
compilation terminated.
Compiling .pio\build\esp32dev\lib649\SPI\SPI.cpp.o
*** [.pio\build\esp32dev\src\main.cpp.o] Error 1
In file included from C:/Users/gabri/.platformio/packages/framework-arduinoespressif32/libraries/SPI/src/SPI.cpp:22:
C:/Users/gabri/.platformio/packages/framework-arduinoespressif32/libraries/SPI/src/SPI.h:24:10: fatal error: stdlib.h: No such file or directory
* Looking for stdlib.h dependency? Check our library registry!
* CLI  > platformio lib search "header:stdlib.h"
* Web  > https://registry.platformio.org/search?q=header:stdlib.h
 #include <stdlib.h>
*** [.pio\build\esp32dev\lib649\SPI\SPI.cpp.o] Error 1
============================================================================== [FAILED] Took 3.69 seconds ==============================================================================
Delete that folder, looks like a broken toolchain.
Yes thanks it work😊, I have delete toolchain-xtensa-esp32 and framework-arduinoespressif32
|-- SPI @ 2.0.0
|-- TinyGSM @ 0.11.7
|-- RTClib @ 2.1.4
|-- Alarm
|-- Farm
|-- FileManager
|-- LocalClock
|-- MQTTComponent
|-- Network
|-- Relay
|-- SimA7672
|-- StoringVariables
|-- Wifisetup
Compiling .pio\build\esp32dev\libcb6\Update\HttpsOTAUpdate.cpp.o
Compiling .pio\build\esp32dev\libcb6\Update\Updater.cpp.o
Compiling .pio\build\esp32dev\libf09\WiFi\WiFi.cpp.o
Compiling .pio\build\esp32dev\libf09\WiFi\WiFiAP.cpp.o
Compiling .pio\build\esp32dev\libf09\WiFi\WiFiClient.cpp.o
Compiling .pio\build\esp32dev\libf09\WiFi\WiFiGeneric.cpp.o
Compiling .pio\build\esp32dev\libf09\WiFi\WiFiMulti.cpp.o
Compiling .pio\build\esp32dev\libf09\WiFi\WiFiSTA.cpp.o
Compiling .pio\build\esp32dev\libf09\WiFi\WiFiScan.cpp.o
Compiling .pio\build\esp32dev\libf09\WiFi\WiFiServer.cpp.o
Compiling .pio\build\esp32dev\libf09\WiFi\WiFiUdp.cpp.o
Compiling .pio\build\esp32dev\lib6a4\WiFiClientSecure\WiFiClientSecure.cpp.o
Archiving .pio\build\esp32dev\libcb6\libUpdate.a
Archiving .pio\build\esp32dev\lib649\libSPI.a
Compiling .pio\build\esp32dev\lib6a4\WiFiClientSecure\esp_crt_bundle.c.o
In file included from src/main.cpp:11:
lib/MQTTComponent/MQTTComponent.h:6: warning: "MQTT_MAX_PACKET_SIZE" redefined
 #define MQTT_MAX_PACKET_SIZE 2048
In file included from lib/MQTTComponent/MQTTComponent.h:5,
.pio/libdeps/esp32dev/PubSubClient/src/PubSubClient.h:26: note: this is the location of the previous definition
 #define MQTT_MAX_PACKET_SIZE 256
Compiling .pio\build\esp32dev\lib6a4\WiFiClientSecure\ssl_client.cpp.o
Compiling .pio\build\esp32dev\lib032\HTTPClient\HTTPClient.cpp.o
In file included from lib/OtaFirmwareUpdate/OtaFirmwareUpdate.h:9,
                 from src/main.cpp:3:
lib/StoringVariables/StoringVariables.h:93:194: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
     char *relayNames[16] = {"Fan 1", "Fan 2", "Fan 3", "Fan 4", "Fan 5", "Cpad 1", "Cpad 2", "Heater", "Lights", "Feeder 1", "Feeder 2", "Feeder 3", "Feeder 4", "Cutain 1", "Curtain 2", "Alarm"};
Compiling .pio\build\esp32dev\lib1cc\FS\FS.cpp.o
Compiling .pio\build\esp32dev\lib1cc\FS\vfs_api.cpp.o
Compiling .pio\build\esp32dev\libbd2\LittleFS\LittleFS.cpp.o
Archiving .pio\build\esp32dev\libf09\libWiFi.a
Compiling .pio\build\esp32dev\lib948\SPIFFS\SPIFFS.cpp.o
Compiling .pio\build\esp32dev\libf59\OTAdrive\FlashUpdater.cpp.o
Compiling .pio\build\esp32dev\libf59\OTAdrive\FlashUpdater8266.cpp.o
Compiling .pio\build\esp32dev\libf59\OTAdrive\KeyValueList.cpp.o
Compiling .pio\build\esp32dev\libf59\OTAdrive\otadrive_esp.cpp.o
Archiving .pio\build\esp32dev\lib6a4\libWiFiClientSecure.a
Compiling .pio\build\esp32dev\libf59\OTAdrive\otadrive_misc.cpp.o
Compiling .pio\build\esp32dev\libf59\OTAdrive\tinyHTTP.cpp.o
Compiling .pio\build\esp32dev\lib454\PubSubClient\PubSubClient.cpp.o
Compiling .pio\build\esp32dev\libb14\ModbusMaster\ModbusMaster.cpp.o
Archiving .pio\build\esp32dev\lib1cc\libFS.a
Compiling .pio\build\esp32dev\lib617\Wire\Wire.cpp.o
Archiving .pio\build\esp32dev\lib032\libHTTPClient.a
Archiving .pio\build\esp32dev\libbd2\libLittleFS.a
Compiling .pio\build\esp32dev\libeed\Adafruit BusIO\Adafruit_BusIO_Register.cpp.o
Archiving .pio\build\esp32dev\lib948\libSPIFFS.a
Compiling .pio\build\esp32dev\libeed\Adafruit BusIO\Adafruit_I2CDevice.cpp.o
Compiling .pio\build\esp32dev\libeed\Adafruit BusIO\Adafruit_SPIDevice.cpp.o
Compiling .pio\build\esp32dev\libd39\RTClib\RTC_DS1307.cpp.o
Compiling .pio\build\esp32dev\libd39\RTClib\RTC_DS3231.cpp.o
Compiling .pio\build\esp32dev\libd39\RTClib\RTC_Micros.cpp.o
Compiling .pio\build\esp32dev\libd39\RTClib\RTC_Millis.cpp.o
Compiling .pio\build\esp32dev\libd39\RTClib\RTC_PCF8523.cpp.o
Compiling .pio\build\esp32dev\libd39\RTClib\RTC_PCF8563.cpp.o
Compiling .pio\build\esp32dev\libd39\RTClib\RTClib.cpp.o
Compiling .pio\build\esp32dev\libdf6\FileManager\FileManager.cpp.o
Archiving .pio\build\esp32dev\lib617\libWire.a
Archiving .pio\build\esp32dev\libb14\libModbusMaster.a
Archiving .pio\build\esp32dev\lib454\libPubSubClient.a
Archiving .pio\build\esp32dev\libf59\libOTAdrive.a
Compiling .pio\build\esp32dev\lib74a\Alarm\Alarm.cpp.o
Archiving .pio\build\esp32dev\libeed\libAdafruit BusIO.a
Archiving .pio\build\esp32dev\libd39\libRTClib.a
Compiling .pio\build\esp32dev\lib5d7\LocalClock\localClock.cpp.o
Compiling .pio\build\esp32dev\lib952\Sensor\Sensor.cpp.o
Compiling .pio\build\esp32dev\libcdf\Preferences\Preferences.cpp.o
Compiling .pio\build\esp32dev\libd69\StoringVariables\StoringVariables.cpp.o
Compiling .pio\build\esp32dev\lib3bc\Farm\Farm.cpp.o
Archiving .pio\build\esp32dev\lib952\libSensor.a
Archiving .pio\build\esp32dev\lib5d7\libLocalClock.a
Compiling .pio\build\esp32dev\lib38b\SimA7672\SimA7672.cpp.o
Archiving .pio\build\esp32dev\libcdf\libPreferences.a
Archiving .pio\build\esp32dev\libdf6\libFileManager.a
Archiving .pio\build\esp32dev\lib74a\libAlarm.a
Compiling .pio\build\esp32dev\libec7\Wifisetup\Wifisetup.cpp.o
Compiling .pio\build\esp32dev\lib512\Network\Network.cpp.o
In file included from lib/StoringVariables/StoringVariables.cpp:1:
Compiling .pio\build\esp32dev\lib227\MQTTComponent\MQTTComponent.cpp.o
In file included from lib/Farm/Farm.h:6,
                 from lib/Farm/Farm.cpp:1:
Compiling .pio\build\esp32dev\lib163\OtaFirmwareUpdate\OtaFirmwareUpdate.cpp.o
Archiving .pio\build\esp32dev\libec7\libWifisetup.a
Archiving .pio\build\esp32dev\libd69\libStoringVariables.a
Archiving .pio\build\esp32dev\lib38b\libSimA7672.a
In file included from lib/MQTTComponent/MQTTComponent.cpp:1:
Compiling .pio\build\esp32dev\lib83e\Relay\Relay.cpp.o
Archiving .pio\build\esp32dev\lib512\libNetwork.a
Archiving .pio\build\esp32dev\lib3bc\libFarm.a
Compiling .pio\build\esp32dev\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\FirmwareMSC.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\HWCDC.cpp.o
In file included from lib/MQTTComponent/MQTTComponent.h:9,
Compiling .pio\build\esp32dev\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\IPv6Address.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\MD5Builder.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\Print.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\StreamString.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\Tone.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\USB.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\USBCDC.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\USBMSC.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\WString.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\base64.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\cbuf.cpp.o
                 from lib/OtaFirmwareUpdate/OtaFirmwareUpdate.cpp:1:
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-adc.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-bt.c.o
Archiving .pio\build\esp32dev\lib163\libOtaFirmwareUpdate.a
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-cpu.c.o
In file included from lib/Relay/Relay.h:14,
                 from lib/Relay/Relay.cpp:1:
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-dac.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-gpio.c.o
Archiving .pio\build\esp32dev\lib83e\libRelay.a
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-i2c-slave.c.o
Archiving .pio\build\esp32dev\lib227\libMQTTComponent.a
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-i2c.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-ledc.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-matrix.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-misc.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-psram.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-rgb-led.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-rmt.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-sigmadelta.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-spi.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-time.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-timer.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-tinyusb.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-touch.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-uart.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\firmware_msc_fat.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\libb64\cdecode.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\libb64\cencode.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\main.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\stdlib_noniso.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\esp32dev\libFrameworkArduino.a
Linking .pio\build\esp32dev\firmware.elf
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
RAM:   [==        ]  16.5% (used 53992 bytes from 327680 bytes)
Flash: [=======   ]  69.0% (used 904529 bytes from 1310720 bytes)
Building .pio\build\esp32dev\firmware.bin
esptool.py v4.5.1
Creating esp32 image...
Merged 27 ELF sections
===================================================================== [SUCCESS] Took 25.68 seconds =====================================================================
