I'm struggling to get started with ESP-PROG debugging
As a new user I’m having some trouble debugging an ESP32-WROOM-32 with ESP-PROG.
I can build, upload and monitor various projects OK.
I’ve followed the document: Get started with ESP-IDF and ESP32-DevKitC: debugging, unit testing, project analysis — PlatformIO latest documentation
and Brian Lough’s document: Use the PlatformIO Debugger on the ESP32 Using an ESP-prog - Hackster.io
Whenever I attempt to run the debugger:
The debug toolbar is displayed with reset and stop options enabled only.
The project builds in debug mode, compiles links etc and shows [SUCCESS] Took 12.20 seconds
The debug toolbar is no longer displayed.
Nothing else happens. No breakpoints hit, no messages, nothing.
Some other clues:
For the commands build, upload etc. a toast message is displayed:
There are task errors. See the output for details.
The OUTPUT tab of the Terminal shows the message:
Error: The PlatformIO task detection didn’t contribute a task for the following configuration:
“type”: “PlatformIO”,
“task”: “Pre-Debug”,
“problemMatcher”: [
“$platformio”
“label”: “PlatformIO: Build in debug mode”
The task will be ignored.
The DEBUG CONSOLE tab of the Terminal always shows the message:
Could not start debugger process > Error: spawn platformio ENOENT
Does anyone have any suggestions?
  • full platformio.ini and sketch code?
  • list of installed VSCode extensions?
  • PIO extension is the latest version?
  • VSCode is the latest version?
  • output of pio system info in a CLI?
; Build options: build flags, source filter, extra scripting
; Upload options: custom port, speed and extra flags
; Redirecting...
[env:mhetesp32devkit]
board = mhetesp32devkit
;upload_port = COM5
debug_tool = esp-prog
VSCode Extensions:
austin.code-gnu-global
cschlosser.doxdocgen
ecmel.vscode-html-css
firefox-devtools.vscode-firefox-debug
formulahendry.code-runner
GitHub.vscode-pull-request-github
googlecloudtools.cloudcode
jeff-hykin.better-cpp-syntax
mindaro-dev.file-downloader
mindaro.mindaro
ms-azuretools.vscode-docker
ms-dotnettools.csharp
ms-kubernetes-tools.vscode-kubernetes-tools
ms-python.python
ms-toolsai.jupyter
ms-vscode-remote.remote-containers
ms-vscode-remote.remote-ssh
ms-vscode-remote.remote-ssh-edit
ms-vscode-remote.remote-wsl
ms-vscode.azure-account
ms-vscode.azurecli
ms-vscode.cmake-tools
ms-vscode.cpptools
ms-vscode.cpptools-extension-pack
ms-vscode.cpptools-themes
ms-vscode.notepadplusplus-keybindings
ms-vsliveshare.vsliveshare
platformio.platformio-ide
redhat.vscode-commons
redhat.vscode-yaml
tht13.html-preview-vscode
twxs.cmake
PlatformIO version:
  • Core 5.2.0a6
  • Home 3.3.4
VSCode about:
Version: 1.57.1 (system setup)
Commit: 507ce72a4466fbb27b715c3722558bb15afa9f48
Date: 2021-06-17T13:28:07.755Z
Electron: 12.0.7
Chrome: 89.0.4389.128
Node.js: 14.16.0
V8: 8.9.255.25-electron.0
OS: Windows_NT x64 10.0.19043
I’m sorry I don’t know how or where to run “pio system info” - not recognised in any terminal.
pio system info:
PlatformIO Core 5.2.0a6
Python 3.9.2-final.0
System Type windows_amd64
Platform Windows-10
File System Encoding utf-8
Locale Encoding cp1252
PlatformIO Core Directory C:\Users\andiarc.platformio
PlatformIO Core Executable C:\Users\andiarc.platformio\penv\Scripts\platformio.exe
Python Executable c:\users\andiarc.platformio\penv\scripts\python.exe
Global Libraries 0
Development Platforms 1
Tools & Toolchains 18
Well that’s definitely a problem. You did follow the doc link to open a PIO terminal? Also accessible in the PIO sidebar
I guessed that not being able to execute pio in the CLI is a conflicting extension messing with the PATH environment variable or Python environment. Usually a sign of the Anaconda extension, but you don’t have that installed.
That extension is known to break PlatformIO per https://github.com/platformio/platformio-vscode-ide/issues/2481. That’s the first extension that should be deactivated.
If that’s the Austin C++ IntelliSense extension, that’s also known to conflict with PlatformIO.
If that still does not help, reduce the installed extension to just PlatformIO, C/C++ by Microsoft, Python and Jupyter.
Thank you @maxgearhardt, I am now debugging. :smiley:
I uninstalled all extensions except:
ms-vscode.cpptools
I still get the toast message and the error in the OUTPUT tab, but the DEBUG CONSOLE tab now has some activity. I’ve had a few false starts, just need more practice.
Thanks again.
