So, when I put my header file (and its related .c file) in the “include” folder, I get this error
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (3.3.0) > Arduino Uno
- framework-arduino-avr 5.1.0
Found 6 compatible libraries
Compiling .pio\build\uno\src\main.c.o
Archiving .pio\build\uno\libFrameworkArduinoVariant.a
Compiling .pio\build\uno\FrameworkArduino\CDC.cpp.o
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial.cpp.o
src\main.c: In function 'main':
src\main.c:55:11: warning: unused variable 'adcVal' [-Wunused-variable]
uint16_t adcVal = adcConvert();
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial0.cpp.o
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial1.cpp.o
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial2.cpp.o
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial3.cpp.o
Compiling .pio\build\uno\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\uno\FrameworkArduino\PluggableUSB.cpp.o
Compiling .pio\build\uno\FrameworkArduino\Print.cpp.o
Compiling .pio\build\uno\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\uno\FrameworkArduino\Tone.cpp.o
Compiling .pio\build\uno\FrameworkArduino\USBCore.cpp.o
Compiling .pio\build\uno\FrameworkArduino\WInterrupts.c.o
Compiling .pio\build\uno\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\uno\FrameworkArduino\WString.cpp.o
Compiling .pio\build\uno\FrameworkArduino\abi.cpp.o
Compiling .pio\build\uno\FrameworkArduino\hooks.c.o
Compiling .pio\build\uno\FrameworkArduino\main.cpp.o
Compiling .pio\build\uno\FrameworkArduino\new.cpp.o
Compiling .pio\build\uno\FrameworkArduino\wiring.c.o
Compiling .pio\build\uno\FrameworkArduino\wiring_analog.c.o
Compiling .pio\build\uno\FrameworkArduino\wiring_digital.c.o
Compiling .pio\build\uno\FrameworkArduino\wiring_pulse.S.o
Compiling .pio\build\uno\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\uno\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\uno\libFrameworkArduino.a
Linking .pio\build\uno\firmware.elf
C:\Users\class\AppData\Local\Temp\ccqy0WB0.ltrans0.ltrans.o: In function `main':
<artificial>:(.text.startup+0x0): undefined reference to `adcConfig'
<artificial>:(.text.startup+0x4): undefined reference to `adcConvert'
*** [.pio\build\uno\firmware.elf] Error 1
================================================================================================== [FAILED] Took 7.39 seconds ==================================================================================================
The terminal process "C:\Users\class\.platformio\penv\Scripts\platformio.exe 'run', '--environment', 'uno'" terminated with exit code: 1.
This is what my project folders look like:
Atmega328p_ADC.h contains the function prototypes and Atmega328p_ADC.c has the function definitions. The functions I call from this library from inside main are what I get errors for.
