Everything is still working until I update the esp32 software to version 4.4.0.
error on this line
#if !defined(MBEDTLS_KEY_EXCHANGE__SOME__PSK_ENABLED) && !defined(MBEDTLS_KEY_EXCHANGE_SOME_PSK_ENABLED)
# warning "Please configure IDF framework to include mbedTLS -> Enable pre-shared-key ciphersuites and activate at least one cipher"
#else
The picture below is about sdkconfig in the arduinoespressif32 framework. it seems like KEY_EXCHANGE is already defined here, and I don’t know why the PlatformIO is still in error.
In my project is included a library that depends on mbedtls. So, What should I do about this?
Thank you for your answer and attention.
Can you upload a minimal project that reproduces this error?
This is the library that I used in my project GitHub - gravitech-engineer/AIS_IoT_4G: Arduino library for AIS 4G Board
I try to include the GSMClientSecure
but it failed. before that, it was still working.
I already found it!!
this is code in AIS IoT 4G
and this code in the WiFiClientSecure
#else
I changed it according to WiFiClientSecure which makes it work again.
Could you open an issue in the library to let them know their build breaks with the new Arduino core?
