> Executing task in folder esp8266-hunter-sprinkler: C:\Users\abdulkadir\.platformio\penv\Scripts\platformio.exe run <
Processing nodemcuv2 (platform: espressif8266; board: nodemcuv2; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/nodemcuv2.html
PLATFORM: Espressif 8266 (3.2.0) > NodeMCU 1.0 (ESP-12E Module)
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
- framework-arduinoespressif8266 @ 3.30002.0 (3.0.2)
- tool-esptool @ 1.413.0 (4.13)
- tool-esptoolpy @ 1.30000.201119 (3.0.0)
- toolchain-xtensa @ 2.100300.210717 (10.3.0)
Found 39 compatible libraries
|-- ESP Async WebServer @ 1.2.3+sha.f71e3d4
| |-- ESPAsyncTCP @ 1.2.2+sha.1547686
| |-- Hash @ 1.0
| |-- ESP8266WiFi @ 1.0
|-- ESP8266HTTPClient @ 1.2
|-- HunterRoam
|-- DNSServer @ 1.1.1
Compiling .pio\build\nodemcuv2\src\main.cpp.o
Compiling .pio\build\nodemcuv2\src\web_server.cpp.o
Compiling .pio\build\nodemcuv2\src\web_server_api.cpp.o
Compiling .pio\build\nodemcuv2\src\web_server_scheduled.cpp.o
Compiling .pio\build\nodemcuv2\src\wifi.cpp.o
Generating LD script .pio\build\nodemcuv2\ld\local.eagle.app.v6.common.ld
Compiling .pio\build\nodemcuv2\lib9ba\ESPAsyncTCP@src-50aade01aa3c160f78f117ac1d851d09\AsyncPrinter.cpp.o
Compiling .pio\build\nodemcuv2\lib9ba\ESPAsyncTCP@src-50aade01aa3c160f78f117ac1d851d09\ESPAsyncTCP.cpp.o
Compiling .pio\build\nodemcuv2\lib9ba\ESPAsyncTCP@src-50aade01aa3c160f78f117ac1d851d09\ESPAsyncTCPbuffer.cpp.o
Compiling .pio\build\nodemcuv2\lib9ba\ESPAsyncTCP@src-50aade01aa3c160f78f117ac1d851d09\SyncClient.cpp.o
Compiling .pio\build\nodemcuv2\lib9ba\ESPAsyncTCP@src-50aade01aa3c160f78f117ac1d851d09\tcp_axtls.c.o
Compiling .pio\build\nodemcuv2\lib95c\Hash\Hash.cpp.o
Compiling .pio\build\nodemcuv2\lib76b\ESP8266WiFi\BearSSLHelpers.cpp.o
Compiling .pio\build\nodemcuv2\lib76b\ESP8266WiFi\CertStoreBearSSL.cpp.o
Compiling .pio\build\nodemcuv2\lib76b\ESP8266WiFi\ESP8266WiFi.cpp.o
Compiling .pio\build\nodemcuv2\lib76b\ESP8266WiFi\ESP8266WiFiAP.cpp.o
Compiling .pio\build\nodemcuv2\lib76b\ESP8266WiFi\ESP8266WiFiGeneric.cpp.o
Compiling .pio\build\nodemcuv2\lib76b\ESP8266WiFi\ESP8266WiFiGratuitous.cpp.o
src\wifi.cpp:10:10: fatal error: ESPAsyncWiFiManager.h: No such file or directory
* Looking for ESPAsyncWiFiManager.h dependency? Check our library registry!
* CLI > platformio lib search "header:ESPAsyncWiFiManager.h"
* Web > https://registry.platformio.org/search?q=header:ESPAsyncWiFiManager.h
10 | #include <ESPAsyncWiFiManager.h>
compilation terminated.
*** [.pio\build\nodemcuv2\src\wifi.cpp.o] Error 1
src\web_server_scheduled.cpp: In function 'void sendResult(String, String)':
src\web_server_scheduled.cpp:29:9: warning: unused variable 'result' [-Wunused-variable]
29 | int result = http.POST(toSend);
================================================================================================== [FAILED] Took 2.85 seconds ==================================================================================================
The terminal process "C:\Users\abdulkadir\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
Is alanswx/ESPAsyncWiFiManager@^0.31
part of your lib_deps
expression in the platformio.ini
