Left pic was from PlatformIO Library Downloads.
Right pic was from GitHub.
It’s all going to happen, but can anyone tell anyone in PlatformIO?
I got hooked…
I got hooked…
The author of the library has not increased the version number since 2018, although commits have been done in July 2019. Thus, PlatformIO will not pick up the library changes without a version increase.
Judging from update to get in line with latest Arduino Framework by leojz · Pull Request #10 · yasheena/telnetspy · GitHub the repo seems to be dead. You can however still force PlatformIO to use the latest Github version by declaring
https://github.com/yasheena/telnetspy.git
in the platformio.ini
(docs).
Hi Max.
Thank you for your information!!
I used lib_deps directive.
Its OK!!!Thank you a lot!
[env:esp8266-ota]
platform = espressif8266
board = esp_wroom_02
board_build.mcu = esp8266
board_build.f_cpu = 80000000L
board_build.f_flash = 40000000L
board_build.flash_mode = qio
-DESP8266
upload_protocol = espota
upload_port = esp8266.local
targets = upload
board_build.ldscript = eagle.flash.1m128.ld
