I cant run ethernet program W5500 on platformio with arduino framework
Trying to run following ethernet w5500 program on platformio. Not able to run it, is there any configuration i need to set in platform.ini file?
#include <ETH.h>
#include <SPI.h>
// Set this to 1 to enable dual Ethernet support
#define USE_TWO_ETH_PORTS 0
#ifndef ETH_PHY_TYPE
#define ETH_PHY_TYPE ETH_PHY_W5500
#define ETH_PHY_ADDR 1
#define ETH_PHY_CS   15
#define ETH_PHY_IRQ  4
#define ETH_PHY_RST  5
// SPI pins
#define ETH_SPI_SCK  14
#define ETH_SPI_MISO 12
#define ETH_SPI_MOSI 13
#if USE_TWO_ETH_PORTS
// Second port on shared SPI bus
#ifndef ETH1_PHY_TYPE
#define ETH1_PHY_TYPE ETH_PHY_W5500
#define ETH1_PHY_ADDR 1
#define ETH1_PHY_CS   32
#define ETH1_PHY_IRQ  33
#define ETH1_PHY_RST  18
ETHClass ETH1(1);
static bool eth_connected = false;
void onEvent(arduino_event_id_t event, arduino_event_info_t info) {
  switch (event) {
    case ARDUINO_EVENT_ETH_START:
      Serial.println("ETH Started");
      //set eth hostname here
      ETH.setHostname("esp32-eth0");
      break;
    case ARDUINO_EVENT_ETH_CONNECTED: Serial.println("ETH Connected"); break;
    case ARDUINO_EVENT_ETH_GOT_IP:    Serial.printf("ETH Got IP: '%s'\n", esp_netif_get_desc(info.got_ip.esp_netif)); Serial.println(ETH);
      Serial.println(ETH1);
      eth_connected = true;
      break;
    case ARDUINO_EVENT_ETH_LOST_IP:
      Serial.println("ETH Lost IP");
      break;
    case ARDUINO_EVENT_ETH_DISCONNECTED:
      Serial.println("ETH Disconnected");
      break;
    case ARDUINO_EVENT_ETH_STOP:
      Serial.println("ETH Stopped");
      break;
    default: break;
void testClient(const char *host, uint16_t port) {
  Serial.print("\nconnecting to ");
  Serial.println(host);
  NetworkClient client;
  if (!client.connect(host, port)) {
    Serial.println("connection failed");
    return;
  client.printf("GET / HTTP/1.1\r\nHost: %s\r\n\r\n", host);
  while (client.connected() && !client.available());
  while (client.available()) {
    Serial.write(client.read());
  Serial.println("closing connection\n");
  client.stop();
  Network.onEvent(onEvent);
  SPI.begin(ETH_SPI_SCK, ETH_SPI_MISO, ETH_SPI_MOSI);
  ETH.begin(ETH_PHY_TYPE, ETH_PHY_ADDR, ETH_PHY_CS, ETH_PHY_IRQ, ETH_PHY_RST, SPI);
  ETH1.begin(ETH1_PHY_TYPE, ETH1_PHY_ADDR, ETH1_PHY_CS, ETH1_PHY_IRQ, ETH1_PHY_RST, SPI);
  if (eth_connected) {
    testClient("google.com", 80);
  delay(10000);
This is because this code is for Espressif Arduino Core version 3.x, which is not (yet) available on PlatformIO (officially).
To get access to Espressif32 Arduino version 3.0.2, you can add the following lines to your platformio.ini:
platform_packages=
  framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git#3.0.2
  framework-arduinoespressif32-libs @ https://github.com/espressif/arduino-esp32/releases/download/3.0.2/esp32-arduino-libs-3.0.2.zip
