I can not add the DHT (Adafruit) Lib to Wemos D1 8266 Plattform
I try to use the DHT Lib from Ada, but I always get an Error 1…
Here the log:
>Processing d1 (platform: espressif8266; board: d1; framework: arduino)
----------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: ht t p s : / / d o c s . p l a t f o r m i o . o r g /page/boards/espressif8266/d1.html
PLATFORM: Espressif 8266 (3.2.0) > WEMOS D1 R1
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
 - framework-arduinoespressif8266 3.30002.0 (3.0.2)
 - tool-esptool 1.413.0 (4.13)
 - tool-esptoolpy 1.30000.201119 (3.0.0)
 - toolchain-xtensa 2.100300.210717 (10.3.0)
LDF: Library Dependency Finder -> h t t p s : / / b i t . l y / c o n f i g u r e - p i o -ldf
Library Manager: Installing DHT sensor library
Unpacking  [------------------------------------]    0%
Unpacking  [##----------------------------------]    6%
Unpacking  [####--------------------------------]   12%
Unpacking  [######------------------------------]   18%
Unpacking  [#########---------------------------]   25%
Unpacking  [###########-------------------------]   31%
Unpacking  [#############-----------------------]   37%
Unpacking  [###############---------------------]   43%
Unpacking  [##################------------------]   50%
Unpacking  [####################----------------]   56%
Unpacking  [######################--------------]   62%
Unpacking  [########################------------]   68%
Unpacking  [###########################---------]   75%
Unpacking  [#############################-------]   81%
Unpacking  [###############################-----]   87%
Unpacking  [#################################---]   93%
Unpacking  [####################################]  100%
Library Manager: DHT sensor library @ 1.4.3 has been installed!
Library Manager: Installing dependencies...
Library Manager: Installing Adafruit Unified Sensor
Unpacking  [##----------------------------------]    7%
Unpacking  [#####-------------------------------]   15%
Unpacking  [########----------------------------]   23%
Unpacking  [###########-------------------------]   30%
Unpacking  [#############-----------------------]   38%
Unpacking  [################--------------------]   46%
Unpacking  [###################-----------------]   53%
Unpacking  [######################--------------]   61%
Unpacking  [########################------------]   69%
Unpacking  [###########################---------]   76%
Unpacking  [##############################------]   84%
Unpacking  [#################################---]   92%
Library Manager: Adafruit Unified Sensor @ 1.1.4 has been installed!
Found 37 compatible libraries
|-- <DHT sensor library> 1.4.3
Compiling .pio\build\d1\src\main.cpp.o
Generating LD script .pio\build\d1\ld\local.eagle.app.v6.common.ld
Compiling .pio\build\d1\lib4bb\DHT sensor library\DHT.cpp.o
Compiling .pio\build\d1\lib4bb\DHT sensor library\DHT_U.cpp.o
Archiving .pio\build\d1\libFrameworkArduinoVariant.a
Compiling .pio\build\d1\FrameworkArduino\Crypto.cpp.o
In file included from .pio\libdeps\d1\DHT sensor library\DHT_U.cpp:15:
.pio\libdeps\d1\DHT sensor library\DHT_U.h:36:10: fatal error: Adafruit_Sensor.h: No such file or directory
* Looking for Adafruit_Sensor.h dependency? Check our library registry!
* CLI  > platformio lib search "header:Adafruit_Sensor.h"
* Web  > h t t p s : / / p l a t f o r m i o . o r g / l i b / s e a r c h ? q u e r y = h e a d e r : Adafruit_Sensor.h
   36 | #include <Adafruit_Sensor.h>
compilation terminated.
Compiling .pio\build\d1\FrameworkArduino\Esp-frag.cpp.o
Compiling .pio\build\d1\FrameworkArduino\Esp-version.cpp.o
Compiling .pio\build\d1\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\d1\FrameworkArduino\FS.cpp.o
Compiling .pio\build\d1\FrameworkArduino\FSnoop.cpp.o
Compiling .pio\build\d1\FrameworkArduino\FunctionalInterrupt.cpp.o
*** [.pio\build\d1\lib4bb\DHT sensor library\DHT_U.cpp.o] Error 1
============================== [FAILED] Took 4.51 seconds ==============================Der Terminalprozess "C:\Users\drhel\.platformio\penv\Scripts\platformio.exe 'run'" wurde mit folgendem Exitcode beendet: 1.
Do anyone have a solution for this issue, coz I can’t find any in the web…
THX
TecDoc
This shows up with PlatformIO Registry. So try adding that library? In the project’s platformio.ini file, you should have both libraries:
     adafruit/DHT sensor library @ ^1.4.3
     adafruit/Adafruit Unified Sensor @ ^1.1.4
and also make sure that you main sketch file at elast includes DHT.h so that the library dependency finder is triggered to search for all its dependencies.
pio lib install 31 && pio lib install 18
