Hello every one i am new in Platform io i am trying to create a new project on the platform io but every time the are showing same error.
pls help i tried lots of time thats why i came here pls help, i try multiple time try to instal and uninstall the platform io and espressif 32 platform but everytime showing same isuue
and and i update my gitbsh and initialize in c:/user/
that will create .git folder
Could not initialize project
Resolving nodemcu-32s dependencies...
Already up-to-date.
Updating metadata for the vscode IDE...
UserSideException: Processing nodemcu-32s (platform: espressif32; board: nodemcu-32s; framework: espidf)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/nodemcu-32s.html
PLATFORM: Espressif 32 (6.4.0) > NodeMCU-32S
- framework-espidf @ 3.50101.230828 (5.1.1)
- tool-cmake @ 3.16.4
- tool-idf @ 1.0.1
- tool-mconf @ 1.4060000.20190628 (406.0.0)
- tool-ninja @ 1.9.0
- tool-riscv32-esp-elf-gdb @ 11.2.0+20220823
- tool-xtensa-esp-elf-gdb @ 11.2.0+20230208
- toolchain-esp32ulp @ 1.23500.220830 (2.35.0)
- toolchain-xtensa-esp32 @ 12.2.0+20230208
-- Found Git: C:/Program Files/Git/cmd/git.exe (found version "2.42.0.windows.2")
-- The C compiler identification is GNU 12.2.0
-- The CXX compiler identification is GNU 12.2.0
-- The ASM compiler identification is GNU
-- Found assembler: C:/Users/ict-n03L/.platformio/packages/toolchain-xtensa-esp32/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: C:/Users/ict-n03L/.platformio/packages/toolchain-xtensa-esp32/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: C:/Users/ict-n03L/.platformio/packages/toolchain-xtensa-esp32/bin/xtensa-esp32-elf-gcc.exe -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: C:/Users/ict-n03L/.platformio/packages/toolchain-xtensa-esp32/bin/xtensa-esp32-elf-g++.exe
-- Check for working CXX compiler: C:/Users/ict-n03L/.platformio/packages/toolchain-xtensa-esp32/bin/xtensa-esp32-elf-g++.exe -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Could not use 'git describe' to determine PROJECT_VER.
-- Building ESP-IDF components for target esp32
-- Project sdkconfig file C:/Users/ict-n03L/Documents/PlatformIO/Projects/2309_ict/sdkconfig.nodemcu-32s
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of time_t
-- Check size of time_t - done
-- Found Python3: C:/Users/ict-n03L/.platformio/penv/.espidf-5.1.1/Scripts/python.exe (found version "3.11.4") found components: Interpreter
-- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS
-- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS - Success
-- App "2309_ict" version: 1
-- Adding linker script C:/Users/ict-n03L/Documents/PlatformIO/Projects/2309_ict/.pio/build/nodemcu-32s/esp-idf/esp_system/ld/memory.ld
-- Adding linker script C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_system/ld/esp32/sections.ld.in
-- Adding linker script C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_rom/esp32/ld/esp32.rom.ld
-- Adding linker script C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_rom/esp32/ld/esp32.rom.api.ld
-- Adding linker script C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_rom/esp32/ld/esp32.rom.libgcc.ld
-- Adding linker script C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_rom/esp32/ld/esp32.rom.newlib-data.ld
-- Adding linker script C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_rom/esp32/ld/esp32.rom.syscalls.ld
-- Adding linker script C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_rom/esp32/ld/esp32.rom.newlib-funcs.ld
-- Adding linker script C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/soc/esp32/ld/esp32.peripherals.ld
-- Components: __pio_env app_trace app_update bootloader bootloader_support bt cmock console cxx driver efuse esp-tls esp_adc esp_app_format esp_coex esp_common esp_eth esp_event esp_gdbstub esp_hid esp_http_client esp_http_server esp_https_ota esp_https_server esp_hw_support esp_lcd esp_local_ctrl esp_mm esp_netif esp_netif_stack esp_partition esp_phy esp_pm esp_psram esp_ringbuf esp_rom esp_system esp_timer esp_wifi espcoredump esptool_py fatfs freertos hal heap http_parser idf_test ieee802154 json log lwip mbedtls mqtt newlib nvs_flash openthread partition_table perfmon protobuf-c protocomm pthread sdmmc soc spi_flash spiffs src tcp_transport ulp unity usb vfs wear_levelling wifi_provisioning wpa_supplicant xtensa
-- Component paths: C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/__pio_env C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/app_trace C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/app_update C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/bootloader C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/bootloader_support C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/bt C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/cmock C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/console C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/cxx C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/driver C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/efuse C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp-tls C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_adc C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_app_format C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_coex C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_common C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_eth C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_event C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_gdbstub C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_hid C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_http_client C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_http_server C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_https_ota C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_https_server C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_hw_support C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_lcd C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_local_ctrl C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_mm C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_netif C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_netif_stack C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_partition C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_phy C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_pm C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_psram C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_ringbuf C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_rom C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_system C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_timer C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esp_wifi C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/espcoredump C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/esptool_py C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/fatfs C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/freertos C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/hal C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/heap C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/http_parser C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/idf_test C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/ieee802154 C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/json C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/log C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/lwip C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/mbedtls C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/mqtt C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/newlib C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/nvs_flash C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/openthread C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/partition_table C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/perfmon C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/protobuf-c C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/protocomm C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/pthread C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/sdmmc C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/soc C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/spi_flash C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/spiffs C:/Users/ict-n03L/Documents/PlatformIO/Projects/2309_ict/src C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/tcp_transport C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/ulp C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/unity C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/usb C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/vfs C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/wear_levelling C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/wifi_provisioning C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/wpa_supplicant C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/xtensa
-- Configuring incomplete, errors occurred!
See also "C:/Users/ict-n03L/Documents/PlatformIO/Projects/2309_ict/.pio/build/nodemcu-32s/CMakeFiles/CMakeOutput.log".
CMake Error at .pio/build/nodemcu-32s/CMakeFiles/git-data/grabRef.cmake:48 (file):
file failed to open for reading (No such file or directory):
C:/Users/ict-n03L/Documents/PlatformIO/Projects/2309_ict/.pio/build/nodemcu-32s/CMakeFiles/git-data/head-ref
C:/Users/ict-n03L/.platformio/packages/framework-espidf/tools/cmake/third_party/GetGitRevisionDescription.cmake:83 (include)
C:/Users/ict-n03L/.platformio/packages/framework-espidf/tools/cmake/third_party/GetGitRevisionDescription.cmake:93 (get_git_head_revision)
C:/Users/ict-n03L/.platformio/packages/framework-espidf/tools/cmake/build.cmake:70 (git_describe)
C:/Users/ict-n03L/.platformio/packages/framework-espidf/tools/cmake/build.cmake:240 (__build_get_idf_git_revision)
C:/Users/ict-n03L/.platformio/packages/framework-espidf/tools/cmake/idf.cmake:53 (__build_init)
C:/Users/ict-n03L/.platformio/packages/framework-espidf/tools/cmake/project.cmake:29 (include)
CMakeLists.txt:2 (include)
C:/Users/ict-n03L/.platformio/packages/framework-espidf/tools/cmake/project.cmake:78 (git_describe)
C:/Users/ict-n03L/.platformio/packages/framework-espidf/tools/cmake/project.cmake:543 (__project_get_revision)
CMakeLists.txt:3 (project)
Compiler supported targets: xtensa-esp32-elf
fatal: Needed a single revision
fatal: not a git repository: C:/Users/ict-n03L/.platformio/packages/framework-espidf/components/openthread/openthread/../../../.git/modules/components/openthread/openthread
========================= [FAILED] Took 18.78 seconds =========================
