I am getting a massive number of compiler warnings (like 47 of 'em) on first compilation of the arduino-libraries/ArduinoBLE library (installed from registry.platformio.org). As only language-level warnings are generated, this just occurs on first compile when the library is initially added to a project (even an empty new project). Obviously I could ignore the warnings (or ini file, build_flags = -w), however, it is mightily disturbing getting such let alone so many warnings - I have to assume I must be doing something wrong. Dozens of PIO/Arduino/Google searches havenât turned up anything helpful let alone anyone else reporting quite this problem. Also, I have been inactive this last year or so, but previously had no such problem with this library.
Other Arduino libraries (ex: [arduino-libraries/Arduino_LSM9DS1] compile just fine. I can upload and run BLE examples fine. This âwarningâ problem occurs without fail both on a clean-built MacBook (2010 / High Sierra - MacOS 10.13.6) and a spanking brand new MacBook Air (2020, M1 chip). I have many times deleted / rebuilt ~/.platformio, ~/.vscode, ~/projectpath/.pio, rebuilt the Intellisense index, etc. All to no effect. While not critical (thoâ I have wasted DAYS isolating this), I sure would appreciate some idea of whatâs going on and how to rectify it.
platformio.ini file:
[env:nano33ble]
platform = nordicnrf52
board = nano33ble
lib_deps = arduino-libraries/ArduinoBLE@^1.3.2
main.cpp
#include <ArduinoBLE.h>
Terminal output:
Executing task: platformio run --environment nano33ble
Processing nano33ble (platform: nordicnrf52; board: nano33ble; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/nordicnrf52/nano33ble.html
PLATFORM: Nordic nRF52 (9.4.0) > Arduino Nano 33 BLE
HARDWARE: NRF52840 64MHz, 256KB RAM, 960KB Flash
DEBUG: Current (blackmagic) External (blackmagic, cmsis-dap, jlink)
- framework-arduino-mbed @ 3.1.1
- tool-sreccat @ 1.164.0 (1.64)
- toolchain-gccarmnoneeabi @ 1.80201.181220 (8.2.1)
Found 38 compatible libraries
|-- ArduinoBLE @ 1.3.2
Compiling .pio/build/nano33ble/src/main.cpp.o
Generating LD script .pio/build/nano33ble/cpp.linker_script.ld
Compiling .pio/build/nano33ble/lib4db/ArduinoBLE/BLEAdvertisingData.cpp.o
Compiling .pio/build/nano33ble/lib4db/ArduinoBLE/BLECharacteristic.cpp.o
Compiling .pio/build/nano33ble/lib4db/ArduinoBLE/BLEDescriptor.cpp.o
Compiling .pio/build/nano33ble/lib4db/ArduinoBLE/BLEDevice.cpp.o
Compiling .pio/build/nano33ble/lib4db/ArduinoBLE/BLEService.cpp.o
Compiling .pio/build/nano33ble/lib4db/ArduinoBLE/BLEStringCharacteristic.cpp.o
Compiling .pio/build/nano33ble/lib4db/ArduinoBLE/BLETypedCharacteristics.cpp.o
Compiling .pio/build/nano33ble/lib4db/ArduinoBLE/local/BLELocalAttribute.cpp.o
Compiling .pio/build/nano33ble/lib4db/ArduinoBLE/local/BLELocalCharacteristic.cpp.o
Compiling .pio/build/nano33ble/lib4db/ArduinoBLE/local/BLELocalDescriptor.cpp.o
Compiling .pio/build/nano33ble/lib4db/ArduinoBLE/local/BLELocalDevice.cpp.o
Compiling .pio/build/nano33ble/lib4db/ArduinoBLE/local/BLELocalService.cpp.o
Compiling .pio/build/nano33ble/lib4db/ArduinoBLE/remote/BLERemoteAttribute.cpp.o
Compiling .pio/build/nano33ble/lib4db/ArduinoBLE/remote/BLERemoteCharacteristic.cpp.o
Compiling .pio/build/nano33ble/lib4db/ArduinoBLE/remote/BLERemoteDescriptor.cpp.o
In file included from .pio/libdeps/nano33ble/ArduinoBLE/src/utility/GATT.h:26,
from .pio/libdeps/nano33ble/ArduinoBLE/src/local/BLELocalCharacteristic.cpp:25:
.pio/libdeps/nano33ble/ArduinoBLE/src/local/BLELocalCharacteristic.h: In constructor 'BLELocalCharacteristic::BLELocalCharacteristic(const char*, uint16_t, int, bool)':
.pio/libdeps/nano33ble/ArduinoBLE/src/local/BLELocalCharacteristic.h:90:12: warning: 'BLELocalCharacteristic::_cccdValue' will be initialized after [-Wreorder]
uint16_t _cccdValue;
.pio/libdeps/nano33ble/ArduinoBLE/src/local/BLELocalCharacteristic.h:79:12: warning: 'uint8_t BLELocalCharacteristic::_permissions' [-Wreorder]
uint8_t _permissions;
.pio/libdeps/nano33ble/ArduinoBLE/src/local/BLELocalCharacteristic.cpp:32:1: warning: when initialized here [-Wreorder]
BLELocalCharacteristic::BLELocalCharacteristic(const char* uuid, uint16_t permissions, int valueSize, bool fixedLength) :
Compiling .pio/build/nano33ble/lib4db/ArduinoBLE/remote/BLERemoteDevice.cpp.o
Compiling .pio/build/nano33ble/lib4db/ArduinoBLE/remote/BLERemoteService.cpp.o
Compiling .pio/build/nano33ble/lib4db/ArduinoBLE/utility/ATT.cpp.o
Compiling .pio/build/nano33ble/lib4db/ArduinoBLE/utility/BLEUuid.cpp.o
Compiling .pio/build/nano33ble/lib4db/ArduinoBLE/utility/GAP.cpp.o
Compiling .pio/build/nano33ble/lib4db/ArduinoBLE/utility/GATT.cpp.o
Compiling .pio/build/nano33ble/lib4db/ArduinoBLE/utility/HCI.cpp.o
Compiling .pio/build/nano33ble/lib4db/ArduinoBLE/utility/HCICordioTransport.cpp.o
.pio/libdeps/nano33ble/ArduinoBLE/src/utility/ATT.cpp: In member function 'virtual bool ATTClass::handleNotify(uint16_t, const uint8_t*, int)':
.pio/libdeps/nano33ble/ArduinoBLE/src/utility/ATT.cpp:592:39: warning: variable length array 'notification' is used [-Wvla]
uint8_t notification[_peers[i].mtu];
.pio/libdeps/nano33ble/ArduinoBLE/src/utility/ATT.cpp: In member function 'virtual bool ATTClass::handleInd(uint16_t, const uint8_t*, int)':
.pio/libdeps/nano33ble/ArduinoBLE/src/utility/ATT.cpp:623:37: warning: variable length array 'indication' is used [-Wvla]
uint8_t indication[_peers[i].mtu];
.pio/libdeps/nano33ble/ArduinoBLE/src/utility/ATT.cpp: In member function 'virtual void ATTClass::findInfoReq(uint16_t, uint16_t, uint8_t, uint8_t*)':
.pio/libdeps/nano33ble/ArduinoBLE/src/utility/ATT.cpp:746:23: warning: variable length array 'response' is used [-Wvla]
uint8_t response[mtu];
.pio/libdeps/nano33ble/ArduinoBLE/src/utility/ATT.cpp: In member function 'virtual void ATTClass::findByTypeReq(uint16_t, uint16_t, uint8_t, uint8_t*)':
.pio/libdeps/nano33ble/ArduinoBLE/src/utility/ATT.cpp:838:23: warning: variable length array 'response' is used [-Wvla]
.pio/libdeps/nano33ble/ArduinoBLE/src/utility/ATT.cpp: In member function 'virtual void ATTClass::readByGroupReq(uint16_t, uint16_t, uint8_t, uint8_t*)':
.pio/libdeps/nano33ble/ArduinoBLE/src/utility/ATT.cpp:896:23: warning: variable length array 'response' is used [-Wvla]
.pio/libdeps/nano33ble/ArduinoBLE/src/utility/ATT.cpp: In member function 'virtual void ATTClass::readOrReadBlobReq(uint16_t, uint16_t, uint8_t, uint8_t, uint8_t*)':
.pio/libdeps/nano33ble/ArduinoBLE/src/utility/ATT.cpp:1003:23: warning: variable length array 'response' is used [-Wvla]
.pio/libdeps/nano33ble/ArduinoBLE/src/utility/ATT.cpp: In member function 'virtual void ATTClass::readByTypeReq(uint16_t, uint16_t, uint8_t, uint8_t*)':
.pio/libdeps/nano33ble/ArduinoBLE/src/utility/ATT.cpp:1118:23: warning: variable length array 'response' is used [-Wvla]
[snip...] [deleted portion much the same as above and below]
Compiling .pio/build/nano33ble/FrameworkArduino/Tone.cpp.o
.pio/libdeps/nano33ble/ArduinoBLE/src/utility/L2CAPSignaling.cpp: In member function 'virtual void L2CAPSignalingClass::handleSecurityData(uint16_t, uint8_t, uint8_t*)':
.pio/libdeps/nano33ble/ArduinoBLE/src/utility/L2CAPSignaling.cpp:296:13: warning: 'i' may be used uninitialized in this function [-Wmaybe-uninitialized]
for(int i; i<6; i++) peerAddress[5-i] = identityAddress->address[i];
Compiling .pio/build/nano33ble/FrameworkArduino/USB/PluggableUSBDevice.cpp.o
Compiling .pio/build/nano33ble/FrameworkArduino/USB/USBCDC.cpp.o
Compiling .pio/build/nano33ble/FrameworkArduino/USB/USBSerial.cpp.o
Archiving .pio/build/nano33ble/lib4db/libArduinoBLE.a
Indexing .pio/build/nano33ble/lib4db/libArduinoBLE.a
Compiling .pio/build/nano33ble/FrameworkArduino/WMath.cpp.o
Compiling .pio/build/nano33ble/FrameworkArduino/abi.cpp.o
Archiving .pio/build/nano33ble/libFrameworkArduinoVariant.a
Indexing .pio/build/nano33ble/libFrameworkArduinoVariant.a
Compiling .pio/build/nano33ble/FrameworkArduino/api/Common.cpp.o
Compiling .pio/build/nano33ble/FrameworkArduino/api/IPAddress.cpp.o
Compiling .pio/build/nano33ble/FrameworkArduino/api/PluggableUSB.cpp.o
Compiling .pio/build/nano33ble/FrameworkArduino/api/Print.cpp.o
Compiling .pio/build/nano33ble/FrameworkArduino/api/Stream.cpp.o
Compiling .pio/build/nano33ble/FrameworkArduino/api/String.cpp.o
Compiling .pio/build/nano33ble/FrameworkArduino/arm_hal_random.c.o
Compiling .pio/build/nano33ble/FrameworkArduino/as_mbed_library/variant.cpp.o
Compiling .pio/build/nano33ble/FrameworkArduino/itoa.c.o
Compiling .pio/build/nano33ble/FrameworkArduino/main.cpp.o
Compiling .pio/build/nano33ble/FrameworkArduino/mbed/platform/cxxsupport/mstd_mutex.cpp.o
Compiling .pio/build/nano33ble/FrameworkArduino/pinToIndex.cpp.o
Compiling .pio/build/nano33ble/FrameworkArduino/random_seed.cpp.o
Compiling .pio/build/nano33ble/FrameworkArduino/timer.cpp.o
Compiling .pio/build/nano33ble/FrameworkArduino/wiring.cpp.o
Compiling .pio/build/nano33ble/FrameworkArduino/wiring_analog.cpp.o
Compiling .pio/build/nano33ble/FrameworkArduino/wiring_digital.cpp.o
Compiling .pio/build/nano33ble/FrameworkArduino/wiring_pulse.cpp.o
Compiling .pio/build/nano33ble/FrameworkArduino/wiring_shift.cpp.o
Archiving .pio/build/nano33ble/libFrameworkArduino.a
Indexing .pio/build/nano33ble/libFrameworkArduino.a
Linking .pio/build/nano33ble/firmware.elf
Checking size .pio/build/nano33ble/firmware.elf
Building .pio/build/nano33ble/firmware.bin
RAM: [=== ] 25.8% (used 67536 bytes from 262144 bytes)
Flash: [=== ] 31.5% (used 309876 bytes from 983040 bytes)
==================================== [SUCCESS] Took 16.06 seconds ====================================
