Huge littlefs.bin file
When I m trying to upload file system image (Data folder) to Wemos d1 mini pro board the generated image file (littlefs.bin) is huge. More than 4gb and of course I m getting ERR: ERROR[4]: Not Enough Space. On Wemos d1 mini board everything working fine.
I checked it in Vscode macOs Catalina (pio core 4.4.0b1 and 4.3.4), Ubuntu desktop 20.04.1 LTS Vscode (pio core 4.3.4), Ubuntu server 18.04.4 LTS (pio core 4.3.4) and Win 10 Vscode (pio core 4.3.4).
Platformio.ini:
[platformio]
default_envs = d1_mini_pro
[env]
platform = espressif8266
upload_protocol = espota
upload_port = 10.0.0.35
	ESPAsyncTCP
	ESP Async WebServer
[env:d1_mini]
board = d1_mini
[env:d1_mini_pro]
board = d1_mini_pro
And my logs in both cases:
>Executing task in folder ESP8266_webserver_spiffs: platformio run --target uploadfs <
    Processing d1_mini_pro (board: d1_mini_pro; platform: espressif8266; framework: arduino)
    CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/d1_mini_pro.html
    PLATFORM: Espressif 8266 (2.6.2) > WeMos D1 mini Pro
    HARDWARE: ESP8266 80MHz, 80KB RAM, 16MB Flash
     - framework-arduinoespressif8266 3.20704.0 (2.7.4)
     - tool-esptool 1.413.0 (4.13)
     - tool-esptoolpy 1.20800.0 (2.8.0)
     - tool-mklittlefs 1.203.200522 (2.3)
     - tool-mkspiffs 1.200.0 (2.0)
     - toolchain-xtensa 2.40802.200502 (4.8.2)
    Found 31 compatible libraries
    |-- <ESPAsyncTCP> 1.2.2
    |   |-- <ESP8266WiFi> 1.0
    |-- <ESP Async WebServer> 1.2.3
    |  |-- <Hash> 1.0
    |-- <ArduinoOTA> 1.0
    |  |-- <ESP8266mDNS> 1.2
    |-- <LittleFS(esp8266)> 0.1.0
    Building file system image from 'data' directory to .pio/build/d1_mini_pro/littlefs.bin
    /index.html
    /main.html
    /style.css
    skipping .DS_Store
    /src/css/doc.css
    /src/css/scheduler.css
    /src/js/scheduler.js
    Uploading .pio/build/d1_mini_pro/littlefs.bin
    21:51:55 [DEBUG]: Options: {'esp_ip': '10.0.0.35', 'host_ip': '0.0.0.0', 'esp_port': 8266, 'host_port': 19920, 'auth': '', 'image': '.pio/build/d1_mini_pro/littlefs.bin', 'spiffs': True, 'debug': True, 'progress': True}
    21:51:55 [INFO]: Starting on 0.0.0.0:19920
    21:52:17 [INFO]: Upload size: 4292845568
    21:52:17 [INFO]: Sending invitation to: 10.0.0.35
    21:52:17 [ERROR]: Bad Answer: ERR: ERROR[4]: Not Enough Space
Processing d1_mini (board: d1_mini; platform: espressif8266; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/d1_mini.html
PLATFORM: Espressif 8266 (2.6.2) > WeMos D1 R2 and mini
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
|   |-- <Hash> 1.0
|-- <ArduinoOTA> 1.0
Building file system image from 'data' directory to .pio/build/d1_mini/littlefs.bin
/index.html
/main.html
/style.css
skipping .DS_Store
/src/css/doc.css
Uploading .pio/build/d1_mini/littlefs.bin
21:49:09 [DEBUG]: Options: {'esp_ip': '10.0.0.35', 'host_ip': '0.0.0.0', 'esp_port': 8266, 'host_port': 57786, 'auth': '', 'image': '.pio/build/d1_mini/littlefs.bin', 'spiffs': True, 'debug': True, 'progress': True}
21:49:09 [INFO]: Starting on 0.0.0.0:57786
21:49:09 [INFO]: Upload size: 1024000
21:49:09 [INFO]: Sending invitation to: 10.0.0.35
Thank you.
Now that’s a really large number, 4GB minus 2072 kilobytes. It reminds me of issue mkspiffs crashes when invoked with negative size parameter · Issue #190 · platformio/platform-espressif8266 · GitHub which however occured with SPIFFS but with the same d1_mini_pro board. The size calculation code may have been copy-pated from the SPIFFS version and still exhibit the same bug though.
Workaround may still be valid by forcing the usage of only 8MB of flash of which 7MB is the filesystem.
board_build.ldscript = eagle.flash.8m7m.ld
@valeros could you have a look at this?
Yes, this workaround is still valid.
Thanks @maxgerhardt !
