The code you provided runs fine on my bluepill for 9600 baud and produces
Hello 5833 56000000
however your ms_delay(1000);
doesn’t give 1000 ms delay because it’s a NOP loop with a constant 500 NOPs per millisecond so that won’t work on all frequences. Systick timer is better here.
Anyways I corrected your PLL code by just doing equal things as this does. You set the wrong PLL multiplier and also forget to modify the flash wait states, so code can’t be able tun run after this.
Corrected method:
void setSystemFreq()
RCC->CIR = 0x009F0000;
// Turn HSE ON
RCC->CR |= RCC_CR_HSEON;
// Wait Until HSE Is Ready
while (!(RCC->CR & RCC_CR_HSERDY))
serialPrint("HSE ON\n");
//set HSE as system clock
RCC->CFGR = (RCC->CFGR & ~(RCC_CFGR_SW)) | RCC_CFGR_SW_HSE;
//AHB prescaler
RCC->CFGR &= ~(RCC_CFGR_HPRE); //remove old prescaler
RCC->CFGR |= RCC_CFGR_HPRE_DIV1; //set AHB prescaler = 1.
//set ADC prescaler = 8
RCC->CFGR &= ~(RCC_CFGR_ADCPRE);
RCC->CFGR |= RCC_CFGR_ADCPRE_DIV8;
//set APB1 prescaler
RCC->CFGR &= ~(RCC_CFGR_PPRE1);
RCC->CFGR |= RCC_CFGR_PPRE1_DIV2;
//set APB2 prescaler
RCC->CFGR &= ~(RCC_CFGR_PPRE2);
RCC->CFGR |= RCC_CFGR_PPRE2_DIV1;
//set flash wait states to 2 wait states
FLASH->ACR &= ~(FLASH_ACR_LATENCY);
FLASH->ACR |= FLASH_ACR_LATENCY_2;
//Set PLL Multiplier
//RCC->CFGR |= 0b1100 << 18;
//at HSE=8MHz, 8*9 = 72MHz.
RCC->CFGR &= ~(RCC_CFGR_PLLMULL);
RCC->CFGR |= RCC_CFGR_PLLMULL9;
// //Set HSE as PLL Source. bit set -> HSE, bit unser -> HSI
RCC->CFGR |= RCC_CFGR_PLLSRC;
// Set HSE Prescaler On PLL Entry
RCC->CFGR &= ~RCC_CFGR_PLLXTPRE;
RCC->CFGR |= RCC_CFGR_PLLXTPRE_HSE; //no HSE prescaler before PLL entry
// Turn On PLL Clock
RCC->CR |= RCC_CR_PLLON;
serialPrint("wait for PLL ON\n");
//ms_delay(1000);
// Wait Until PLL Is Ready
while (!(RCC->CR & RCC_CR_PLLRDY))
serialPrint("PLL rdy\n");
//serialPrint("Clock ON\n");
//ms_delay(1000);
// Set System To PLL CLock
RCC->CFGR = (RCC->CFGR & ~(RCC_CFGR_SW)) | RCC_CFGR_SW_PLL;
serialPrint("switched to PLL clock\n");
// Clear All Interrupts
outputs (with extra prints in clock source enabled)
Hello 7500 72000000
Clock Source : 1
AHB_Prec : 0
Pll_Multiplier : 9
PLL_Source : 1
HSE_Prec : 0
PLL_Freq : 72000000
SystemCoreClock : 72000000
So you have your 72MHz now and the UART still works at 9600 baud.
