I want to use procompile library (.a file ),i followed
other’s ways ,but it does not work.
the .ini
the terminal
the path
the project catalog
the .ini
the terminal
These filenames are already fine, so just do
-ID:/project/RADER/include
-LD:/project/RADER/lib/esp32c3
-lacc_detector_distance
-lacc_detector_presence
-lacc_rf_certification_test
-laccconeer
If that still fails you might have problems with C linkage / name mangling, make sure you
extern "C" {
/* include RADER library header file inside this block, whatever the name is */
#include <libaccooner.h>
