How to use a particular specified native toolchain?
@valeros @vit
I know this is an old thread, but I figured out a way to do this. Posting since I found this while looking for a solution.
In platformio.ini:
[env:native_custom_gcc]
platform = native
extra_scripts = pre:modify_path.py
Then create a python script modify_path.py in your working directory:
import os
os.environ["path"] += "C:/path/to/gcc/"
This will let the platformio find gcc in that directory without modifying your system path. If there is another gcc on path you might need to change this a little so this path is added to the beginning instead of the end of your path.
