I have created a (local) package that that overrides the toolchain (this works), and one that contains my HAL code. Both get installed in the packages directory.
platform_packages =
toolchain-atmelavr@file://c:/ti-software/platformio/avr-gcc-10.2
hwlib@file://c:/ti-software/hwlib
Now I want to use that hwlib from a project. I tried to add it as a dependency, but it isn’t found.
lib_deps = hwlib
How do I use an installed package?
Libraries should not be modeled as packages. Libraries are libraries, PlatformIO handles them natively as such with the library dependency finder and lib_deps
system. If you have HAL code, use a normal library structure as outlined in the standard library readme. Libraries can optionally have a library.json
manifest file, the content of which is vastly different to a package.json
Once you have a valid library folder, do not inject it via platform_packages
, but a regular lib_deps
expression (also see these docs for possible ways to reference a library – via http://, file://, name in the registry, etc.)
Note that if the that library folder is put into the lib/
folder of the project, it is automatically recognized.
Furhter reading: The library dependency finder (LDF).
