I also started with Atmel Studio drivers and had to switch over to libusb drivers when I first bought the Atmel Ice.
I had to install the libusb drivers a couple years ago while working with a different visual studios plugin, and back then it gave me a hard time. I don’t know if it has gotten easier since then. I don’t remember every detail, but libusb wasn’t a “verified” windows driver (or something to that effect), so I had to jump through some hoops to install in on my Windows 10 machine.
@jcsb1994 please let me know how it works out for you.
@oceansource I did not try it yet, is it a destructive procedure? Of course I’d rather have it work with PIO than Atmel Studio but if I install the wrong driver with @maxgerhardt 's website app am I going to be able to try multiple times? And is there a way to go back to the Atmel driver? I’d rather ask since an ICE is $$.
Installing the generic libusb driver should be absolutely harmless to the device, and you can always switch back the drivers in the Windows device manager to the Atmel provided ones, given you know the path to the original drivers. This is also shown in the device manager
Only thread which references a problem was solved by manually selecting the right driver in the device manager again (https://www.avrfreaks.net/comment/2435586#comment-2435586).
I’ve never seen a device which breaks by loading it with generic libusb drivers. As I said, just make sure you know where the original drivers are to switch back.
This is the driver I installed on my atmel ICE. now in the device manager it shows up as a libusb-win32 device. There was another driver I could’ve installed with a similar name, something like libusbk, I dont know if this one would have been better.
It doesn’t seem to change a lot of things when I press upload on platformIO. With this .ini file:
[env:ATmega328P]
platform = atmelavr
board = ATmega328P
upload_protocol = atmelice_isp
upload_flag = -e
I get:
DATA: [ ] 0.4% (used 9 bytes from 2048 bytes)
PROGRAM: [ ] 1.4% (used 444 bytes from 32256 bytes)
AVAILABLE: atmelice_isp
CURRENT: upload_protocol = atmelice_isp
Looking for upload port...
Error: Please specify `upload_port` for environment or use global `--upload-port` option.
For some development platforms it can be a USB flash drive (i.e. /media/<user>/<device name>)
*** [upload] Explicit exit, status 1
So it complains about a missing upload_port argument`. If I add:
upload_port = usb
I get:
Use manually specified: usb
Uploading .pio\build\ATmega328P\firmware.hex
avrdude: usbdev_send(): wrote -22 out of 7 bytes, err =
avrdude: jtag3_send(): failed to send command to serial port
avrdude: failed to sync with the JTAGICE3 in ISP mode
avrdude done. Thank you.
Did I install the right driver? should I create a custom board? (I am kinda worried it looks a little complicated to do). Is it just a matter of typing the right .ini file? thanks again guys…
Yes that is what I did haha…
But now I have both installed (I checked all available devices and there are only 2 Atmel ICE devices with the same address on zadig) and nothing changed. I get the same error reports.
Can you do a verbose upload (pio run -t upload -v
) with
- Atmel-ICE unplugged
- Atmel-ICE plugged in
and post the output, starting at thte avrdude -v
invocation part?
With the ICE unplugged:
avrdude -v -p atmega328p -C C:\Users\Jean-Christophe\.platformio\packages\tool-avrdude\avrdude.conf -c atmelice_isp -b 115200 -D -P "usb" -U flash:w:.pio\build\ATmega328P\firmware.hex:i
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:24:16
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Jean-Christophe\.platformio\packages\tool-avrdude\avrdude.conf"
Using Port : usb
Using Programmer : atmelice_isp
Overriding Baud Rate : 115200
avrdude: jtag3_open_common(): Did not find any device matching VID 0x03eb and PID list: 0x2141
*** [upload] Error 1
====================================================================== [FAILED] Took 7.03 seconds ======================================================================
The terminal process terminated with exit code: 1
With the ICE plugged:
Using Port : usb
avrdude: usbdev_open(): Found Atmel-ICE CMSIS-DAP, serno: J42700010786
avrdude: Found CMSIS-DAP compliant device, using EDBG protocol
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : JTAG3_ISP
Description : Atmel-ICE (ARM/AVR) in ISP mode
Vtarget : 5.1 V
SCK period : 8.00 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: safemode: hfuse reads as D1
avrdude: safemode: efuse reads as FF
avrdude: reading input file ".pio\build\ATmega328P\firmware.hex"
avrdude: writing flash (444 bytes):
Writing | ################################################## | 100% 0.13s
avrdude: 444 bytes of flash written
avrdude: verifying flash memory against .pio\build\ATmega328P\firmware.hex:
avrdude: load data flash data from input file .pio\build\ATmega328P\firmware.hex:
avrdude: input file .pio\build\ATmega328P\firmware.hex contains 444 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.14s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0002
0x14 != 0x34
avrdude: verification error; content mismatch
avrdude: safemode: Fuses OK (E:FF, H:D1, L:F6)
====================================================================== [FAILED] Took 1.62 seconds ======================================================================
*note that if I do not specify upload_port = usb in the .ini, all of this does not appear and it asks for serial port to be defined.
Funny that we’re getting a lot further now.
Looks like the same error as in the referenced thread, missing a upload_flags = -e
in the platformio.ini
to perform a full erase beforehand. Is that already in there?
Yep that looks like an annoying bug, but that workaround is good for now
YESS!!
we worked it out! I managed to blink a led!! Such a relief Thank you so much @maxgerhardt .
I did have upload_flag = -e without the s… I tried removing it last time as I was getting desperate.
I will post a final post on this thread explaining in details what we need to do from scratch to make the ICE work on PIO. Thanks again @maxgerhardt and @oceansource.
meanwhile, here is a video of the dead bugged blinking LED on my atmega328 board haha https://photos.app.goo.gl/sFL1jTm2ihziYVmS6
I am a little late coming to the party… but I have had to grapple with the same issue recently… and this is what works for me…
- Use a custom upload protocol.
This is what my platformio.ini file looks like.
;PlatformIO Project Configuration File
; 'pio run -t fuses' for programming the avr fuses
; 'pio run -t program' for programming the firmware binary
; avrdude -p m328p -c atmelice_isp -U efuse:w:0xFF:m -U hfuse:w:0xD6:m -U lfuse:w:0xE2:m
[env:moteino]
platform = atmelavr
board = moteino8mhz
board_fuses.lfuse = 0xE2
board_fuses.hfuse = 0xD6
board_fuses.efuse = 0xFF
board_build.f_cpu = 8000000UL
upload_protocol = custom
lib_deps = 1419
38
92
126
28
1775
439
upload_flags =
-pm328p
-catmelice_isp
-e
upload_command = avrdude $UPLOAD_FLAGS -U flash:w:$SOURCE:i -C ~/.platformio/packages/tool-avrdude/avrdude.conf
extra_scripts =
post:scripts/post_upload_fuses.py
Use the command “pio run -t program” instead of “pio run -t upload” to actually upload the firmware.
There is an optional post_upload script in case one wishes to flash the fuses as well.
This is the content of the post_upload_fuses.py
Import(“env”, “projenv”)
import subprocess
import os
# access to global construction environment
print(env)
# Dump construction environment (for debug purpose)
print(env.Dump())
def after_upload(source, target, env):
print(“Post upload actions!”)
#command to flash avr fuses to the controller
print(“Burning the AVR fuses”)
# os.system(‘avrdude -p m328p -c atmelice_isp -U efuse:w:0xFF:m -U hfuse:w:0xD6:m -U lfuse:w:0xE2:m’)
subprocess.call(‘avrdude -p m328p -C ~/.platformio/packages/tool-avrdude/avrdude.conf -c atmelice_isp -U efuse:w:0xFF:m -U hfuse:w:0xD6:m -U lfuse:w:0xE2:m’, shell=True)
env.AddPostAction(“program”,after_upload)
Of course, this a very hacky solution hard linking all the directory and file paths. I m sure more knowledgeable folks can do it right with relative paths or using environment variables.
I hope this helps… either now or someone who has the same issue in future…
The solutions are all explained on my blog (hopefully clearly enough) Setting up Atmel-ICE with PlatformIO using ATmega328p – Cyan Sensors
Thanks to your help max and Ocean! I mentioned you on my blog post
Hi guys, I followed the above instruction but with this platformio.ini
file:
[env:leonardo]
platform = atmelavr
board = leonardo
board_build.f_cpu = 8000000L
jandelgado/JLed@^4.11.0
arduino-libraries/ArduinoRS485@^1.0.2
septillion-git/FadeLed@^1.6.0
upload_port = usb
upload_flag = -e
I get the following output:
Using manually specified: usb
Forcing reset using 1200bps open/close on port usb
Waiting for the new upload port...
Error: Couldn't find a board on the selected port. Check that you have the correct port selected. If it is correct, try pressing the board's reset button after initiating the upload.
I have a working Atmel ICE programmer:
$ lsusb | grep Atmel
Bus 001 Device 012: ID 03eb:2141 Atmel Corp. ICE debugger
Ubuntu 22.04. Any idea?
Add
board_upload.wait_for_upload_port = no
board_upload.use_1200bps_touch = no
to the platformio.ini
. Does it still try to wait for serial port?
With those two lines I get this output:
Uploading .pio/build/leonardo/firmware.hex
avrdude: usbdev_open(): WARNING: failed to set configuration 1: Device or resource busy
avrdude: stk500v2_command(): command failed
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
Well now it’s at least trying to talk to the Atmel ICE, but it doesn’t get far. Per other topics like Atmel-ICE with macOS Catalina - #6 by jeanlouis.lumia it should work okay.
There is a post at Unfreeze Your Atmel-ICE – Arduino Craft Corner about a custom avrdude version. Does the last command, adapated to avrdude -c atmelice_isp -p m32u4 -v -t
, show something?
I issued it in a terminal:
$ avrdude -c atmelice_isp -p m32u4 -v -t
avrdude: Version 6.3-20171130
System wide configuration file is "/etc/avrdude.conf"
User configuration file is "/home/marcotrapanese/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : usb
AVR Part : ATmega32U4
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
Vtarget : 0.0 V
SCK period : 1.00 us
avrdude: Short read, read only 0 out of 512 bytes
avrdude: jtag3_edbg_recv(): Unexpected response 0x61
avrdude: stk500v2_jtag3_recv(): error in jtagmkII_recv()
Reading | | 0% 0.00savrdude: jtag3_edbg_send(): Unexpected response 0x81, 0x11
avrdude: jtag3_edbg_recv(): Unexpected response 0x80
avrdude: jtag3_edbg_recv(): Unexpected response 0x71
Reading | ################# | 33% 0.84s
Reading | ################################################## | 100% 1.44s
avrdude: Device signature = 0x303030
avrdude: Expected signature for ATmega32U4 is 1E 95 87
Double check chip, or use -F to override this check.
avrdude: jtag3_edbg_send(): Unexpected response 0xc0, 0x54
avrdude: jtag3_edbg_send(): Unexpected response 0x70, 0x54
avrdude: jtag3_edbg_send(): Unexpected response 0x17, 0x00
avrdude: jtag3_edbg_signoff(): failed to read from serial port (0)
That’s not looking too good. It did find your device this time, but talking to the microcontroller failed completely. Either there is something wrong with the wiring between the AtmelICE and the target board or Atmel ICE firmware somehow has a fault or avrdude still has a fault. Sadly I have neither a Mac nor an Atmel ICE to further investigate this. The next recommended stop would be the avrdude programmers maybe. Issues · avrdudes/avrdude · GitHub
Before you open an issue there it might be worth compiling the very-latest avrdude version yourself and seeing if that created binary has the same problem. See Building AVRDUDE for macOS · avrdudes/avrdude Wiki · GitHub. Make sure to brew remove the old avrdude version.
Atmel Studio (within VirtualBox) programs correctly my board, so both the wirings and the programmer are ok.
I was just looking for a way to program the hex file without running Windows in the virtual machine.
By the way, I’m running Ubuntu 22.04 not a MAC.
