No, it’s just confusing… especially when you have only one board environment defined - that you need to expand the environment for it to access that extra menu. I did mention it somewhere before I’m sure, but will probably have to add an issue for it as it was probably on the forum somewhere.
I was never able to get the fuses writing to work. I have since written a PowerShell script that runs from the terminal to do it. I then used the VsCode Action buttons extension to make it available from the actions bar.
