How to set Flash parameters for RP2040 board?
I’m trying to use an external flash chip as a FAT storage, to expose through USB CSC
Adafruit SPIFlash for the RP2040 requires you to set the flash size “through the Arduino IDE Tools->Flash menu”
I’ve found the entries in the boards.txt, e.g.
challenger_2040_wifi_ble.menu.flash.16777216_15728640.upload.maximum_size=1044480
challenger_2040_wifi_ble.menu.flash.16777216_15728640.build.flash_total=16777216
challenger_2040_wifi_ble.menu.flash.16777216_15728640.build.flash_length=1044480
challenger_2040_wifi_ble.menu.flash.16777216_15728640.build.eeprom_start=285208576
challenger_2040_wifi_ble.menu.flash.16777216_15728640.build.fs_start=269479936
challenger_2040_wifi_ble.menu.flash.16777216_15728640.build.fs_end=285208576
But what do I do with these?
the pico board json doesnt mention flash size/FS size at all.
Doing board_ overrides in platformio.ini using the names from boards.txt has no effect.
I can see this block inside Adafruit_FlashTransport_RP2040.cpp
// symbol from linker that matches 'Tools->Flash Size' menu selection for
// filesystem
extern uint8_t _FS_start;
extern uint8_t _FS_end;
Am I supposed to overwrite/define these in code?
What values do I give them, they are uint8_ts, and the code does this:
// FS Size determined by menu selection
#define MENU_FS_SIZE ((uint32_t)(&_FS_end - &_FS_start))
i.e gets the address of the variables, as though they already exist in ram, but at the flash locations… How do I set this in CPP (if necessary)?
Any other tips on my objective greatly received.
Thanks
Andrew
Per documentation:
To set “Filesystem size”: https://arduino-pico.readthedocs.io/en/latest/platformio.html#flash-size
To set the “Flash Size”: Override the maximum_size in the "upload" section of the board. In general see https://docs.platformio.org/en/latest/boards/raspberrypi/pico.html#configuration.
In total, e.g.,
; 2 MByte of Flash, 1MByte of which is reserved for filesystem
board_upload.maximum_size = 2097152
board_build.filesystem_size = 1m
Given that you should already chose a board = .. that has the correct flash size of the board you physically have, you only need to set the filesystem size.
Ughh i missed that. Will try tomorrow, thanks.
My board is a pico, but has a 16mb qspi flash on it.
How come the standard pico.json doesnt mention any fs size at all?
Thanks
16 Megabit or 16 Megabyte? The standard Pico comes with 2MByte (W25Q16 = 16Mbit). Meaning, board = pico or board = rpipico is already correct to set up the base amount of flash.
Doh. Yeah its MBit
Thanks
