How can I run freertos only on first core on the esp32-wroom when I use the platformIO. I can do this t on the esp-idf,but I don’t know how to do this on the platformIO.
If you can do it in ESP-IDF via setting the right menuconfig
options, then you can do the same in PlatformIO as documented in the CLI.
