I don’t know why the file cannot be found, even tho it is there and I’m in the project folder.
john@83adbc14 ~/Documents/PlatformIO/Projects/Testing MCB1768 ~/.platformio/packages/tool-openocd/bin/openocd -f ~/.platformio/packages/tool-openocd/scripts/interface/cmsis-dap.cfg -f ~/.platformio/packages/tool-openocd/scripts/board/mcb1700.cfg -c "program {{.pio/build/lpc1768/firmware.elf}} verify reset; shutdown;"
xPack OpenOCD, 64-bit Open On-Chip Debugger 0.10.0+dev (2019-07-17-15:21)
Licensed under GNU GPL v2
For bug reports, read
Info : auto-selecting first available session transport "swd". To override use 'transport select <transport>'.
Info : CMSIS-DAP: SWD Supported
Info : CMSIS-DAP: JTAG Supported
Info : CMSIS-DAP: FW Version = 1.0
Info : CMSIS-DAP: Interface Initialised (SWD)
Info : SWCLK/TCK = 0 SWDIO/TMS = 1 TDI = 1 TDO = 1 nTRST = 0 nRESET = 1
Info : CMSIS-DAP: Interface ready
Info : clock speed 10 kHz
Info : SWD DPIDR 0x2ba01477
Info : lpc17xx.cpu: hardware has 6 breakpoints, 4 watchpoints
Info : Listening on port 3333 for gdb connections
target halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x1fff0080 msp: 0x10001ffc
Info : High speed (adapter_khz 12500) may be limited by adapter firmware.
** Programming Started **
Error: couldn't open {.pio/build/lpc1768/firmware.elf}
embedded:startup.tcl:449: Error: ** Programming Failed **
in procedure 'program'
in procedure 'program_error' called at file "embedded:startup.tcl", line 508
at file "embedded:startup.tcl", line 449
