The change to 16 was due to supporting PSRAM enabled boards. The PSRAM default is 16. I’ve been testing with a slightly adjusted values with near 100% success:
#define CONFIG_ESP32_WIFI_DYNAMIC_RX_BUFFER_NUM 32
#define CONFIG_ESP32_WIFI_SOFTAP_BEACON_MAX_LEN 752
#define CONFIG_ESP32_WIFI_DYNAMIC_TX_BUFFER 1
#define CONFIG_ESP32_WIFI_STATIC_RX_BUFFER_NUM 16
#define CONFIG_ESP32_WIFI_TASK_PINNED_TO_CORE_0 1
#define CONFIG_ESP32_WIFI_TX_BA_WIN 6
#define CONFIG_ESP32_WIFI_NVS_ENABLED 0
#define CONFIG_ESP32_WIFI_RX_BA_WIN 16
#define CONFIG_ESP32_WIFI_DYNAMIC_TX_BUFFER_NUM 32
#define CONFIG_ESP32_WIFI_AMPDU_TX_ENABLED 1
#define CONFIG_ESP32_WIFI_TX_BUFFER_TYPE 1
#define CONFIG_ESP32_WIFI_AMPDU_RX_ENABLED 1
I’ll be submitting a PR to bump to values which are compatible and stable for both WROOM-32 (no PSRAM) and WROVER (with PSRAM) boards.
