I have a test project written in native AVR C++. The hardware is just a USBasp connected to a minimal ATmega328P system.
In previous PIO Core 4.3, I always use Upload using Programmer
to upload program to the chip. However, new PIO Core removed the convenient task from task lists. So I just went back to CLI using pio run --target program
, which worked well.
Meanwhile I also discovered the upload_protocol
setting in platformio.ini
, and tried if that will turn Upload
to Upload using Programmer
[env:m328p]
board_build.mcu = atmega328p
board_build.f_cpu = 8000000L
upload_protocol = usbasp
And it did use USBasp, but not working, as avrdude
say verification failure, and of course the chip won’t run. Upload output below:
Uploading .pio/build/m328p/firmware.hex
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file ".pio/build/m328p/firmware.hex"
avrdude: writing flash (320 bytes):
Writing | ################################################## | 100% 0.17s
avrdude: 320 bytes of flash written
avrdude: verifying flash memory against .pio/build/m328p/firmware.hex:
avrdude: load data flash data from input file .pio/build/m328p/firmware.hex:
avrdude: input file .pio/build/m328p/firmware.hex contains 320 bytes
Reading | ################################################## | 100% 0.11s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x007a
0x9a != 0x9e
avrdude: verification error; content mismatch
avrdude: safemode: Fuses OK (E:FD, H:DE, L:FF)
avrdude done. Thank you.
*** [upload] Error 1
============================================================ [FAILED] Took 0.84 seconds ============================================================
The terminal process "platformio 'run', '--target', 'upload'" terminated with exit code: 1.
So I tried Verbose Upload
, and got the arguments for avrdude
avrdude -v -p atmega328p -C /Users/45gfg9/.platformio/packages/tool-avrdude/avrdude.conf -c usbasp -D -U flash:w:.pio/build/m328p/firmware.hex:i
which fails.
Then I tried -v
for --target program
, arguments below:
avrdude -v -p atmega328p -C /Users/45gfg9/.platformio/packages/tool-avrdude/avrdude.conf -c usbasp -U flash:w:.pio/build/m328p/firmware.hex:i
which succeeds.
And notice: target program
doesn’t have -D
flag, in which target upload
has.
-D
disables auto erase, and I don’t see why it affects verification failure.
So the question is: is there a config entry to remove -D
from upload flags?
Didn’t find specific one in documentation as upload_flags
only adds arguments
If not, I may just stuck with CLI then.
