I must state that I am relatively new to PlatformIO and an absolute beginner in Python. I can use standard settings that work for a certain platform such as Arduino Due, but I am struggling with customizing the build process.
I have gone through MaxGerhardt’s explanation for the internals of Platformio again and I have tried to be “smart”. I wanted to tell the environment to employ objcopy in order to convert a hex file form the resulting elf. I must have misunderstood something because to me it does not seem to be clear where that information had to be entered and at which time. I was under the impression that “env” seems like a giant object that contains everything there is to know about the build job, and which can be amended from any script. So I have added the the last section in my “extra_script.py” below which is referenced in platformio.ini. The question is : Why did the builder ignore that instruction? Did it come at the wrong time or from the wrong location? The main.py has a section “Allows the user to override via pre:script”. What does that mean?
The script “extra_script.py” is shown below and the relevant section is contained in the last block, after
#Make sure to obtain a hex file
from os import path
Import("env")
platform = env.PioPlatform()
env.Prepend(
UPLOADERFLAGS=["-s", path.join(platform.get_package_dir("tool-openocd"), "scripts") or "",
"-f", "interface/cmsis-dap.cfg",
"-c", 'set CHIPNAME at91sam3X4E',
'-c', 'source [find target/at91sam3ax_4x.cfg]']
env.Append(
UPLOADERFLAGS=["-c", "telnet_port disabled; program {$SOURCE} 0x80000 verify reset; shutdown"]
env.Replace(
UPLOADER="openocd",
UPLOADCMD="$UPLOADER $UPLOADERFLAGS"
#Make sure to obtain a hex file.
env.Append(
ElfToHex=Builder(
action=env.VerboseAction(" ".join([
"$OBJCOPY",
"-O",
"ihex",
"-R",
".eeprom",
"$SOURCES",
"$TARGET"
]), "Building $TARGET"),
suffix=".hex"
