An serial monitor/terminal with arrow-up for previous commands, and local echo that can be enabled. - basically any terminal program from the 80’s had that.
minicom can do the job just fine, but how to make it properly replace the built-in serial monitor?
You can’t replace the builtin monitor.
But you can use other VS Code Plugins like Serial Monitor or use external programs like putty.
Thank you, this is much better, but there is no way of using it as default? (as after uploading firmware?)
Afaik: no.
(post must have at least 20 chars)
