Hi guys!
First, I used “pio init -b esp32dev --ide=vscode” in an existing project with this command, but there was a problem that the framework property of the .ini file was entered into the arduino.
Then I modified it with espidf, and I tried to hit build and this error came up.
Processing esp32dev (platform: https://github.com/platformio/platform-espressif32.git; board: esp32dev; framework: espidf)
PLATFORM: Espressif 32 (3.0.0+sha.55f50dc) > Espressif ESP32 Dev Module
- framework-espidf 3.40200.210118 (4.2.0)
- tool-cmake 3.16.4
- tool-esptoolpy 1.30000.201119 (3.0.0)
- tool-idf 1.0.1
- tool-mconf 1.4060000.20190628 (406.0.0)
- tool-ninja 1.9.0
- tool-openocd-esp32 2.1000.20201202 (10.0)
- toolchain-esp32ulp 1.22851.191205 (2.28.51)
- toolchain-xtensa32 2.80400.210211 (8.4.0)
KeyError: 'compileGroups':
File "C:\Users\Jay_Kim\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 177:
File "C:\Users\Jay_Kim\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Script\SConscript.py", line 591:
File "C:\Users\Jay_Kim\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Script\SConscript.py", line 280:
File "C:\Users\Jay_Kim\.platformio\platforms\espressif32@src-5f117260f75b328038ec9d3fd0e14a68\builder\main.py", line 225:
File "C:\Users\Jay_Kim\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Util.py", line 658:
File "C:\Users\Jay_Kim\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 61:
env.ProcessProgramDeps()
File "C:\Users\Jay_Kim\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 127:
File "C:\Users\Jay_Kim\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 342:
SConscript(env.GetFrameworkScript(f), exports="env")
File "C:\Users\Jay_Kim\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Script\SConscript.py", line 654:
return method(*args, **kw)
File "C:\Users\Jay_Kim\.platformio\platforms\espressif32@src-5f117260f75b328038ec9d3fd0e14a68\builder\frameworks\espidf.py", line 1170:
project_flags = get_app_flags(project_config, default_config)
File "C:\Users\Jay_Kim\.platformio\platforms\espressif32@src-5f117260f75b328038ec9d3fd0e14a68\builder\frameworks\espidf.py", line 400:
default_flags = _extract_flags(default_config)
File "C:\Users\Jay_Kim\.platformio\platforms\espressif32@src-5f117260f75b328038ec9d3fd0e14a68\builder\frameworks\espidf.py", line 387:
for cg in config["compileGroups"]:
========================================================================================================================================================================= [FAILED] Took 1.39 seconds
How can I fix it…?
And now my code can’t find esp_ble_mesh_defs.h.
It’s good at Espressif IDF…
Help…
