NilsRo
January 22, 2023, 11:14am
#1
Hi.
I have dumps on my ESP32-S2 Lolin and like to get the source as it seems to be a library causing the dump.
I found a very interesting feature with core dump to flash but I did not get it running with PlatformIO as menuconfig is missing. Found some interesting posts but most other are more then 2 years old. So I like to ask if there is an easy way today to enable this function?
Per https://github.com/espressif/esp-idf/releases the latest official version is 4.4-beta1, and it’s PlatformIO policy to only support stable versions – meaning with the current used 4.3.1 version, PlatformIO is still lagging behind the most recent v4.3.2 version from 6 days ago.
However, PlatformIO is adaptive. Through a platform_packages directive you can arbitrarily modify the source of the package framework-espidf, to e.g. point at a specific repository with ESP-IDF v4.4-beta1 with the Pla…
Cheers,
Nils
Are we talking Arduino-ESP32 as framework or base ESP-IDF?
NilsRo
January 24, 2023, 9:48pm
#3
Arduino Framework I think. With ESP-IDF I know that you can start makeconfig.
To be sure this is the ini and the project.
[env:lolin_s2_mini]
board = lolin_s2_mini
board_build.mcu = esp32s2
upload_protocol = espota
upload_port = Luftentfeuchter.ham.lan
This file has been truncated. show original
