I am trying to get value of build_flag
in pre:
build script.
I can get python string list of BUILD_FLAGS
by env.get("BUILD_FLAGS)
, Is there any function available that can return the value of specified BUILD_FLAG is available?
Is there any function that can be used to remove/modify BUILD_FLAGS
similar to ProcessUnFlags
Do you mean raw build_flags
value from platformio.ini
? See example with ConfigParser Redirecting...
Yes, This works fine if all build_flags has a value assigned.
It fails when there is a define like -D ENABLE_DEBUG
with error too many values to unpack:
However, filterning list by the type list
does the job.
def get_build_flag_value(flag_name):
build_flags = env.ParseFlags(env['BUILD_FLAGS'])
flags_with_value_list = [build_flag for build_flag in build_flags.get('CPPDEFINES') if type(build_flag) == list]
defines = {k: v for (k, v) in flags_with_value_list}
return defines.get(flag_name)
