Hello
How can I enable Ansi Colors with PlatformIO with Wokwi no Problem but I don’t get it work regluar
Hello
For the PlatformIO device monitor (miniterm.py) to let through the ANSI codes to the underlying consoles, you have to use (docs)
monitor_filters =
direct
to your platformoi.ini.
If you don’t want any filters at (you could still add more filters onto monitor_filters above) you could also just say (docs)
monitor_raw = yes
in the platformio.ini.
Also discussed previously in e.g. Some bizare characters prints on serial monitor with ESP-IDF hello world example - #26 by pfeerick
