I see that the esp-idf latest has some new functions I would like to try out.
Is there a convenient way of creating two versions of VSCode on the same computer ?
Also, where does Platform IO install the esp-idf source files ?
Why? The VSCode and plugin base can be exactly the same. No need for two VSCode installations.
Every package, an example of which are frameworks, are installed in C:\Users\<user>\.platformio\package
, see framework-espidf
folder.
To make it portable you shouldn’t simple edit this folder, but tell PIO to use your custom version of framework-espidf
. See Redirecting.... The package needs an appropriate package.json
, which can be looked up from the one in the original framework-espidf
with an appropriate version change.
