I’m trying to make the following ini work
[common]
rev_var = !echo "-DPIO_SRC_REV="$(git rev-parse HEAD)
[env]
build_flags = -Wl,-Map=$BUILD_DIR/artifact.map
[env:nodemcuv2_linux]
build_flags = ${env.build_flags} ${common.rev_var}
[env:nodemcuv2_cross]
-DSERVICE_SSID=\"SOME_SSID\"
But rev_var
is not resolved during concat phase in nodemcuv2_linux
and is placed as plain text !echo "-DPIO_SRC_REV="$(git rev-parse HEAD)
Also -D options doesn’t concat to env.build_flags
in nodemcuv2_cross
The goal of the config is to let the project build on Windows and Linux machines and have an option to run git
command or not, depending on environment. Can you tell me if this possible to implement with platformio.ini
config and how?
