(This is an old question that didn’t get a response, edited for simplicity)
In the -I paths below, the ‘espidf’ part refer to the framework version used and should be changed manuall if a different framework version is selected.
Is there a way to define paths such that they will refer to the current framework in use? E.g. using a $FRAMEWORK_DIR like variable.
(These paths are required because ‘jump to definitions’ doesn’t work in stock ESP32 projects).
; Base
[env]
framework = espidf
debug_tool=esp-prog
upload_port=COM6
board_build.partitions = partitions_singleapp_large.csv
upload_speed=921600
; For IntelliSense.
-I$PROJECT_CORE_DIR/packages/framework-espidf/components/driver
-I$PROJECT_CORE_DIR/packages/framework-espidf/components/freertos
[env:release]
build_type = release
[env:debug]
build_type = debug
