I added
[env:native]
platform = native
to platform.ini.
What should I do so CLion recognizes it as new configuration?
I tried to rebuild project index but I got
File "/usr/local/Cellar/platformio/3.5.1/libexec/lib/python2.7/site-packages/platformio/__main__.py", line 90, in main
cli(None, None, None)
File "/usr/local/Cellar/platformio/3.5.1/libexec/lib/python2.7/site-packages/click/core.py", line 764, in __call__
File "/usr/local/Cellar/platformio/3.5.1/libexec/lib/python2.7/site-packages/click/core.py", line 717, in main
rv = self.invoke(ctx)
File "/usr/local/Cellar/platformio/3.5.1/libexec/lib/python2.7/site-packages/platformio/commands/__init__.py", line 37, in invoke
return super(PlatformioCLI, self).invoke(ctx)
File "/usr/local/Cellar/platformio/3.5.1/libexec/lib/python2.7/site-packages/click/core.py", line 1137, in invoke
File "/usr/local/Cellar/platformio/3.5.1/libexec/lib/python2.7/site-packages/click/core.py", line 956, in invoke
File "/usr/local/Cellar/platformio/3.5.1/libexec/lib/python2.7/site-packages/click/core.py", line 555, in invoke
return callback(*args, **kwargs)
File "/usr/local/Cellar/platformio/3.5.1/libexec/lib/python2.7/site-packages/click/decorators.py", line 17, in new_func
File "/usr/local/Cellar/platformio/3.5.1/libexec/lib/python2.7/site-packages/platformio/commands/init.py", line 106, in cli
pg.generate()
File "/usr/local/Cellar/platformio/3.5.1/libexec/lib/python2.7/site-packages/platformio/ide/projectgenerator.py", line 140, in generate
contents = self._render_tpl(tpl_path, tpl_vars)
File "/usr/local/Cellar/platformio/3.5.1/libexec/lib/python2.7/site-packages/platformio/ide/projectgenerator.py", line 145, in _render_tpl
return bottle.template(get_file_contents(tpl_path), **tpl_vars)
File "/usr/local/Cellar/platformio/3.5.1/libexec/bin/bottle.py", line 3624, in template
return TEMPLATES[tplid].render(kwargs)
File "/usr/local/Cellar/platformio/3.5.1/libexec/bin/bottle.py", line 3413, in render
self.execute(stdout, env)
File "/usr/local/Cellar/platformio/3.5.1/libexec/bin/bottle.py", line 3400, in execute
eval(self.co, env)
File "<string>", line 64, in <module>
File "/usr/local/Cellar/platformio/3.5.1/libexec/lib/python2.7/site-packages/platformio/project/helpers.py", line 220, in load_project_ide_data
if len(envs) == 1 and envs[0] in data:
TypeError: 'set' object does not support indexing
`pip install -U platformio` command
https://docs.platformio.org/page/faq.html
