PlatformIO Community
How in include disco_f429zi headers?
#1
I need to use LCD/touch libraries for disco_f429zi. As far as i understand, there are 2 possibilities:
  1. Use built-in libraries, with hardcode absolute lib path in platform.ini
  2. Use https://platformio.org/lib/show/2208/BSP_DISCO_F429ZI
Since hardcoded paths are not acceptable for my project, i tried to use BSP_DISCO_F429ZI. But ldf still fails to include files:
// Both fail to find header
#include "Utilities/Fonts/fonts.h"
#include "fonts.h"
I also could not find any sample projects for disco_f429zi with LCD sample.
Could you guide me to proper direction? That’s not my first pio project, but first attempt to use extended built-in libs.
#2
Compiles for me. You also need https://platformio.org/lib/show/2432/LCD_DISCO_F429ZI
platformio.ini
[env:disco_f429z]
platform = ststm32
board = disco_f429zi
framework = mbed
	BSP_DISCO_F429ZI
	LCD_DISCO_F429ZI
main.cpp from the DISCO-F429ZI_LCD_demo_main.cpp
#include "mbed.h"
#include "LCD_DISCO_F429ZI.h"
LCD_DISCO_F429ZI lcd;
DigitalOut led1(LED1);
int main()
    led1 = 1;
    BSP_LCD_SetFont(&Font20);
    lcd.DisplayStringAt(0, LINE(1), (uint8_t *)"MBED EXAMPLE", CENTER_MODE);
    wait(1);
    while(1)
      lcd.Clear(LCD_COLOR_BLUE);
      lcd.SetBackColor(LCD_COLOR_BLUE);
      lcd.SetTextColor(LCD_COLOR_WHITE);
      wait(0.3);
      lcd.DisplayStringAt(0, LINE(4), (uint8_t *)"DISCOVERY", CENTER_MODE);
      lcd.DisplayStringAt(0, LINE(5), (uint8_t *)"STM32F429ZI", CENTER_MODE);
      wait(1);
      lcd.Clear(LCD_COLOR_GREEN);
      lcd.SetTextColor(LCD_COLOR_BLUE);
      lcd.FillRect(10, 20, 50, 50);
      wait(0.1);
      lcd.SetTextColor(LCD_COLOR_BROWN);
      lcd.FillCircle(80, 80, 50);
      wait(0.1);
      lcd.SetTextColor(LCD_COLOR_YELLOW);
      lcd.FillEllipse(150, 150, 50, 100);
      wait(0.1);
      lcd.SetTextColor(LCD_COLOR_RED);
      lcd.FillCircle(200, 200, 40);
      wait(1);
      lcd.SetBackColor(LCD_COLOR_ORANGE);
      lcd.SetTextColor(LCD_COLOR_CYAN);
      BSP_LCD_SetFont(&Font24);
      lcd.DisplayStringAt(0, LINE(7), (uint8_t *)"HAVE FUN !!!", CENTER_MODE);
      wait(1);
      led1 = !led1;
      wait(0.5);
#3
Works for me: #include <fonts.h>. The library.json of the BSP_DISCO_F429ZI library correctly does
    "build": {
        "flags": [
            "-IDrivers",
            "-IDrivers/BSP",
            "-IDrivers/BSP/STM32F429I-Discovery",
            "-IDrivers/BSP/Components",
            "-IDrivers/BSP/Components/ili9341",
            "-IDrivers/BSP/Components/stmpe811",
            "-IDrivers/BSP/Components/l3gd20",
            "-IDrivers/BSP/Components/Common",
            "-IUtilities",
            "-IUtilities/Fonts"
so since font.h is in Utilities/Fonts/fonts.h it sufficies to so say include <fonts.h> or include <Fonts/fonts.h>
#4
Also with the touch screen you’ll need https://platformio.org/lib/show/2803/TS_DISCO_F429ZI :slight_smile:
#5
@maxgerhardt thanks for example! I found the root of problem. All those packages are restricted to mbed framework in manifest, but i use stm32cube. So, libraries were silently excluded from build.
Is it possible to fix issue for stm32cube? Created a test repo https://github.com/puzrin/pio_disco_test
See this line https://github.com/puzrin/pio_disco_test/blob/master/src/main.c#L11 As far as i understand, it exists in stm32cube framework too, but include fails.
#6
Hmm even if you add -I $PIOHOME_DIR/packages/framework-stm32cube/f4/Drivers/BSP/STM32F429I-Discovery the #include <stm32f429i_discovery.h> is found but it doesn’t compile the objects file in that library. The STM32Cube builder script doesn’t seem to process the Drivers/BSP/<board_variant> files? (@ivankravets) Only everything in Drivers\BSP\Components.
Note that there is a lib_compat_mode = off possibility (https://docs.platformio.org/en/latest/projectconf/section_env_library.html#lib-compat-mode) but sadly the BSP_DISCO_F429ZI has an mbed-os specific include so it won’t work in this case.
The easiest way to get it working is to copy .platformio\packages\framework-stm32cube\f4\Drivers\BSP\STM32F429I-Discovery into lib/STM32F429I-Discovery and rewrite the include paths in the code
See pull-request https://github.com/puzrin/pio_disco_test/pull/1
Note that to get a working firmware you must initialize the HAL and setup handlers as in https://github.com/platformio/platform-ststm32/blob/master/examples/stm32cube-hal-blink/src/main.c
#7
Also if you look at the LCD libraries, every function just forwards the execution into the BSP_XXX functitons so the examples should actually be really easy to port to STM32Cube by calling the wrapped functions directly instead of the C++ object functions. https://os.mbed.com/teams/ST/code/LCD_DISCO_F429ZI/file/dc55a068bc1a/LCD_DISCO_F429ZI.cpp/
#8
@valeros should it be fixed on our side?
#9
Thanks for detailed explanations. I’m familiar with hacks via lib/ and use it often, when have no time to investigate details. But scope if this thread was to understand how to do things “right and beautiful” :slight_smile:.
I’m not sure if this should be posted to tracker or it’s my mistake because something is done wrong.
Sure. Sample repo is just a minimal cut to demonstrate problem. It skips a lot of thing from real project.
#10
Okay this has a second part. There is code that attempts to do that
However the path that it constructs here in my case is C:\Users\Maxi\.platformio\packages\framework-stm32cube\f4\Drivers\BSP\DISCO_F429ZI and not C:\Users\Maxi\.platformio\packages\framework-stm32cube\f4\Drivers\BSP\STM32F429I-Discovery. In general variant may not correspond to the folder names inside that directory.
#11
There is nothing to fix as it’s already implemented. Probably just need to add a new entry with this board to the variant_remap.json file.
#12
You’re right. The platformio\packages\framework-stm32cube\platformio\variants_remap.json is missing the entry
"disco_f429zi": "STM32F429I-Discovery",
in this case.
#13
Yes. Clean way:
Add "disco_f429zi": "STM32F429I-Discovery" as an entry the JSON file variants_remap.json
Write the platformio.ini as
[env:stm32f429_disco]
platform = ststm32
framework = stm32cube
        BSP-ili9341
main.c
#include "stm32f429i_discovery.h"
#include <stm32f429i_discovery_lcd.h>
int main(void)
        BSP_GetVersion();
        BSP_LCD_Init();
or more sophisticated
#include <stm32f4xx_hal.h>
#define LCD_FRAME_BUFFER_LAYER0                  (LCD_FRAME_BUFFER+0x130000)
#define LCD_FRAME_BUFFER_LAYER1                  LCD_FRAME_BUFFER
#define CONVERTED_FRAME_BUFFER                   (LCD_FRAME_BUFFER+0x260000)
int main(void)
	HAL_Init();
	BSP_LCD_Init();
	BSP_LCD_LayerDefaultInit(1, LCD_FRAME_BUFFER_LAYER1);
	BSP_LCD_SelectLayer(1);
	BSP_LCD_Clear(LCD_COLOR_WHITE);
	BSP_LCD_SetColorKeying(1, LCD_COLOR_WHITE);
	BSP_LCD_SetLayerVisible(1, DISABLE);
	BSP_LCD_LayerDefaultInit(0, LCD_FRAME_BUFFER_LAYER0);
	BSP_LCD_SelectLayer(0);
	BSP_LCD_SetFont(&Font16);
	BSP_LCD_DisplayOn();
	//clear LCD
	//set font (and size)
	//display string
	BSP_LCD_DisplayStringAt(0, LINE(1), (uint8_t *)"MBED EXAMPLE", CENTER_MODE);
	//endless loop
	while(1);
void SysTick_Handler(void)
  HAL_IncTick();
void NMI_Handler(void)
void HardFault_Handler(void)
  while (1) {}
void MemManage_Handler(void)
  while (1) {}
void BusFault_Handler(void)
  while (1) {}
void UsageFault_Handler(void)
  while (1) {}
void SVC_Handler(void)
void DebugMon_Handler(void)
void PendSV_Handler(void)
and delete all previous lib/ folders, no duplication needed. I guess @valeros will fix this is upstream soon.
#14
@maxgerhardt could you explain how BSP-ili9341 dependency works in your sample? It not exists in registry. Is it really needed?
#15
Yes, otherwise the ILI9341 driver (framework-stm32cube\f4\Drivers\BSP\Components\ili9341) won’t be compiled and you will get an undefinded reference to .. error when calling BSP_LCD_XXX functions. The needed name is comprised of BSP- plus the folder name inside Components/, see the Python code at
#16
Hm… do i understand right, this code dynamically register ghost BSP-* libs as “available for use”?
Seems this feature is not documented anywhere in stm32cube platform docs. Probably worth to add - even with correct variant_remap.json i could not resolve this without your help.
#17
Seems alternative is to add
#include <ili9341.h>
somewhere. Also works, but without warning “library not found”.
