Hi All!
STM32Duino executed 1.7 version of its framework. When it can be released into PIO?
Hi All!
Hi @Vladislav_Kravchenko! The package is already updated, but not released yet. You can try it in the upstream version of the ststm32 platform.
And when it can be released?
There is no ETA, as soon as there is significant amount of changes or bugfixes.
Tried with no success
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/nucleo_f103rb.html
Error: This board doesn't support arduino framework!
PLATFORM: ST STM32 1.7.0 > ST Nucleo F103RB
HARDWARE: STM32F103RBT6 72MHz, 20KB RAM, 128KB Flash
PACKAGES: tool-stm32duino 1.0.1, framework-arduinoststm32 2.0.170723, toolchain-gccarmnoneeabi 1.40804.0 (4.8.4), tool-stlink 1.10200.1 (1.2.0)
With pio.ini:
[env:nucleo_f103rb]
platform = ststm32@1.7.0
What to adjust?
[env:nucleo_f103rb]
platform = https://github.com/platformio/platform-ststm32.git
That gives even more strange result:
PlatformManager: Installing platform-ststm32
git version 2.22.0.windows.1
Cloning into 'C:\Users\Vladislav\.platformio\platforms\_tmp_installing-rq0ys0-package'...
remote: Enumerating objects: 449, done.
remote: Counting objects: 100% (449/449), done.
remote: Compressing objects: 100% (235/235), done.
remote: Total 449 (delta 291), reused 302 (delta 186), pack-reused 0
Receiving objects: 100% (449/449), 1.63 MiB | 382.00 KiB/s, done.
Resolving deltas: 100% (291/291), done.
Submodule 'builder/frameworks/libopencm3' (https://github.com/platformio/builder-framework-libopencm3.git) registered for path 'builder/frameworks/libopencm3'
Cloning into 'C:/Users/Vladislav/.platformio/platforms/_tmp_installing-rq0ys0-package/builder/frameworks/libopencm3'...
remote: Enumerating objects: 43, done.
remote: Total 43 (delta 0), reused 0 (delta 0), pack-reused 43
Submodule path 'builder/frameworks/libopencm3': checked out '39e2eed656463acef1cf70a34fc9db5f73a5540c'
ststm32 @ b469aef has been successfully installed!
File "c:\users\vladislav\.platformio\penv\lib\site-packages\platformio\__main__.py", line 90, in main
cli(None, None, None)
File "c:\users\vladislav\.platformio\penv\lib\site-packages\click\core.py", line 764, in __call__
File "c:\users\vladislav\.platformio\penv\lib\site-packages\click\core.py", line 717, in main
rv = self.invoke(ctx)
And even more errors with recommendation to report this issue to developers
It looks like something went wrong, but the platform was installed successfully. Were you able to compile any example with Arduino framework?
It seems that I can’t create a new project. PIO IDE reports:
Server error: {"args":[2,"No such file or directory"],"message":"[Errno 2] No such file or directory: 'C:\\\\Users\\\\Vladislav\\\\.platformio\\\\platforms\\\\Arduino_Core_STM32\\\\platform.json'","type":"IOError"}
and
PIO Core Call Error: "Error: Traceback (most recent call last):\n File \"c:\\users\\vladislav\\.platformio\\penv\\lib\\site-packages\\platformio\\__main__.py\", line 90, in main\n cli(None, None, None)\n File \"c:\\users\\vladislav\\.platformio\\penv\\lib\\site-packages\\click\\core.py\", line 764, in __call__\n return self.main(*args, **kwargs)\n File \"c:\\users\\vladislav\\.platformio\\penv\\lib\\site-packages\\click\\core.py\", line 717, in main\n rv = self.invoke(ctx)\n File \"c:\\users\\vladislav\\.platformio\\penv\\lib\\site-packages\\platformio\\commands\\__init__.py\", line 37, in invoke\n return super(PlatformioCLI, self).invoke(ctx)\n File \"c:\\users\\vladislav\\.platformio\\penv\\lib\\site-packages\\click\\core.py\", line 1137, in invoke\n return _process_result(sub_ctx.command.invoke(sub_ctx))\n File \"c:\\users\\vladislav\\.platformio\\penv\\lib\\site-packages\\click\\core.py\", line 956, in invoke\n return ctx.invoke(self.callback, **ctx.params)\n File \"c:\\users\\vladislav\\.platformio\\penv\\lib\\site-packages\\click\\core.py\", line 555, in invoke\n return callback(*args, **kwargs)\n File \"c:\\users\\vladislav\\.platformio\\penv\\lib\\site-packages\\platformio\\commands\\boards.py\", line 31, in cli\n return _print_boards_json(query, installed)\n File \"c:\\users\\vladislav\\.platformio\\penv\\lib\\site-packages\\platformio\\commands\\boards.py\", line 67, in _print_boards_json\n for board in _get_boards(installed):\n File \"c:\\users\\vladislav\\.platformio\\penv\\lib\\site-packages\\platformio\\commands\\boards.py\", line 62, in _get_boards\n return pm.get_installed_boards() if installed else pm.get_all_boards()\n File \"c:\\users\\vladislav\\.platformio\\penv\\lib\\site-packages\\platformio\\managers\\platform.py\", line 191, in get_all_boards\n boards = self.get_installed_boards()\n File \"c:\\users\\vladislav\\.platformio\\penv\\lib\\site-packages\\platformio\\util.py\", line 61, in wrapper\n self.cache[key] = (time.time(), func(*args, **kwargs))\n File \"c:\\users\\vladislav\\.platformio\\penv\\lib\\site-packages\\platformio\\managers\\platform.py\", line 179, in get_installed_boards\n p = PlatformFactory.newPlatform(manifest['__pkg_dir'])\n File \"c:\\users\\vladislav\\.platformio\\penv\\lib\\site-packages\\platformio\\managers\\platform.py\", line 260, in newPlatform\n _instance = platform_cls(join(platform_dir, \"platform.json\"))\n File \"c:\\users\\vladislav\\.platformio\\penv\\lib\\site-packages\\platformio\\managers\\platform.py\", line 497, in __init__\n self._manifest = fs.load_json(manifest_path)\n File \"c:\\users\\vladislav\\.platformio\\penv\\lib\\site-packages\\platformio\\fs.py\", line 54, in load_json\n with open(file_path, \"r\") as f:\nIOError: [Errno 2] No such file or directory: 'C:\\\\Users\\\\Vladislav\\\\.platformio\\\\platforms\\\\Arduino_Core_STM32\\\\platform.json'\n\n============================================================\n\nAn unexpected error occurred. Further steps:\n\n* Verify that you have the latest version of PlatformIO using\n
pip install -U platformiocommand\n\n* Try to find answer in FAQ Troubleshooting section\n https://docs.platformio.org/page/faq.html\n\n* Report this problem to the developers\n https://github.com/platformio/platformio-core/issues\n\n============================================================"
If I return platform platform = ststm32 back then I can compile my old code. But still can’t make a new project due to the errors above. After restarting of VSCode - the same thing. Can’t start a new project.
Hm, what is this folder for? It shouldn’t be there. Please delete all folders that don’t start with platform-*
and all folders with platform-ststm32
in its name.
Success, you are the magician!
After removing of the folder I can compile my code and start new project.
