I’m a first time platformio user. I have a project from github that I want to load and install onto an ESP32 device.
I have downloaded the .zip from github and extracted it. The project has a platformio.ini file in the root directory and two folders named “lib” and “src”.
I know this sounds simple, but how do I load the project from the IDE so that the file paths are correct for the dependent files in the subfolders. It looks like the IDE has several ways to start a project, but I can’t work out what to do. I’ve tried a few things, but still get compile errors when it cannot find the required files.
I’ve looked for tutorials but none explain my use case.
