How do I include a file in the src directory from a file in the lib directory?
How do I include a file in the src directory from a file in the lib directory? For example:
lib/thelibrary/thefile.cpp:
#include "config.h"
int something[SOME_CONSTANT];
src/config.h:
#define SOME_CONSTANT 32
The error message says it can’t find config.h. I also tried “…/…/src/config.h”.
Thanks for your help :slight_smile:
Hi @jordanapplewhite!
How about adding special build_flags option to your platformio.ini:
[env:your_env]
platform = your_platform
framework = your_framework
board = your_board
build_flags = -I$PROJECTSRC_DIR
