First of all I’m very new for PlatformIO and I can’t find anything about that. I want to create multiple folders. After than that I need run files with my selection. I don’t want to initialize repository for each file.
Such as: platformio run blabla.ino
Is it possible? Thanks in advance. Also, I use command line interface not IDE.
platformio init generates valid PlatformIO project. You should have 2 different project in this case. If you don’t want to do that (I don’t recommend), you can use different build environments and src_filter.
