HID.h cannot find PluggableUSB.h with Arduino Leonardo
Greetings,
I have been trying to write code in the Platformio extension in VSCode using the Keyboard.h library with a Arduino Leonardo, one of the boards that supports the Keyboard.h library. First, I had a dependency issue with Keyboard.h not being able to find HID.h, but I managed to resolve that. Now, HID.h is unable to find PluggableUSB.h, one of the libraries in the Arduino core. I have no idea why it cannot find it, and its not a library available from the Platformio library manager. What am I doing wrong?
Below this is the minimal code I have been attempting to compile:
#include <HID.h>
#include <Keyboard.h>
#include <PluggableUSB.h>
// put function declarations here:
void setup()
void loop()
This is my platformio.ini file:
[env:leonardo]
board = leonardo
	arduino-libraries/Keyboard@^1.0.6
	Wire@^1.0
	mitchman631/HID@^1.0
This the error I get when trying to compile:
 *  Executing task: platformio run
Processing leonardo (platform: atmelavr; board: leonardo; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/leonardo.html
PLATFORM: Atmel AVR (5.1.0) > Arduino Leonardo
HARDWARE: ATMEGA32U4 16MHz, 2.50KB RAM, 28KB Flash
DEBUG: Current (simavr) External (simavr)
 - framework-arduino-avr @ 5.2.0
Found 7 compatible libraries
|-- Keyboard @ 1.0.6
|-- Wire @ 1.0
|-- HID @ 1.0.0
Compiling .pio/build/leonardo/src/main.cpp.o
Compiling .pio/build/leonardo/lib709/HID/HID.cpp.o
Compiling .pio/build/leonardo/libe07/Keyboard/Keyboard.cpp.o
.pio/libdeps/leonardo/HID/HID.cpp:19:10: fatal error: USB/PluggableUSB.h: No such file or directory
 #include "USB/PluggableUSB.h"
compilation terminated.
Compiling .pio/build/leonardo/libe07/Keyboard/KeyboardLayout_en_US.cpp.o
*** [.pio/build/leonardo/lib709/HID/HID.cpp.o] Error 1
In file included from .pio/libdeps/leonardo/Keyboard/src/Keyboard.h:25:0,
                 from .pio/libdeps/leonardo/Keyboard/src/Keyboard.cpp:22:
.pio/libdeps/leonardo/HID/HID.h:24:10: fatal error: USB/PluggableUSB.h: No such file or directory
In file included from src/main.cpp:2:0:
*** [.pio/build/leonardo/libe07/Keyboard/Keyboard.cpp.o] Error 1
*** [.pio/build/leonardo/src/main.cpp.o] Error 1
==================================================================== [FAILED] Took 0.97 seconds ====================================================================
 *  The terminal process "platformio 'run'" terminated with exit code: 1.
The HID library is already built into the Arduino-core for the Leonardo, so it’s wrong to include mitchman631/HID@^1.0. Same for the Wire library.
So, you should just have
[env:leonardo]
board = leonardo
While also deleting the .pio folder of the project to get rid of the old libraries. Then, a Keyboard example sketch like this one should work fine.
Oh so manually including HID.h and Wire.h screwed things up then, because it compiled fine once I removed them. I would not have expected that. Thank you!
