Hi Community
I’m desperately trying to compile my code for adafruit_qtpy_esp32s2 which perfectly worked for more than 12 month until yesterday. Yesterday, I temporarily added a new board (xiao esp32c3) to platformio.ini.
Since then (and after removing the newly added xiao config again) I cannot compile my code anymore. I even created a new windows user and reinstalled platformio but the result stayed the same.
I get gross errors like those for WiFi.h and Update.h:
.pio/libdeps/adafruit_qtpy_esp32s2/WebSockets/src/WebSockets.h:205:10: fatal error: WiFi.h: No such file or directory
and
.pio/libdeps/adafruit_qtpy_esp32s2/ArduinoOTA/src/InternalStorageESP.cpp:24:10: fatal error: Update.h: No such file or director
There are also errors in my ADC routines where I use ESP32 specific structs.
But those files are on my disk: C:\Users\me\.platformio\packages\framework-arduinoespressif32\libraries\WiFi\src\WiFi.h
and C:\Users\me\.platformio\packages\framework-arduinoespressif32\libraries\Update\src\Update.h
So far I never took much notice of the dependency graph. Should there be more?
Also, most probably, the framework-arduinoespressif32 version is highter than I had it (I hardly updated libs before because they were just working).
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/adafruit_qtpy_esp32s2.html
PLATFORM: Espressif 32 (6.2.0+sha.da13338) > Adafruit QT Py ESP32-S2
HARDWARE: ESP32S2 240MHz, 320KB RAM, 4MB Flash
- framework-arduinoespressif32 @ 3.20008.0 (2.0.8)
- toolchain-xtensa-esp32s2 @ 8.4.0+2021r2-patch5
Found 41 compatible libraries
|-- ArduinoJson @ 6.21.2
|-- ArduinoOTA @ 1.0.9
|-- WebSockets @ 2.3.7
| |-- SPI @ 2.0.0
|-- Adafruit NeoPixel @ 1.10.4
|-- SPI @ 2.0.0
My config looks like this ans is unchanged:
[env:adafruit_qtpy_esp32s2]
board = adafruit_qtpy_esp32s2
test_framework = unity
bblanchon/ArduinoJson@^6.19.4
jandrassy/ArduinoOTA@^1.0.9
links2004/WebSockets@^2.3.7
extra_scripts =
pre:scripts/preBuild.py
post:scripts/postBuild.py
build_src_filter =
${env.build_src_filter}
-<driver>
+<driver/arduino>
-<main_*.cpp>
${env.build_flags}
-I lib/hsm
-I lib/base64/src
-I src/utils
-I src/Extensions
#upload_port = COM13
Any help much appreciated. And thanks for reading!
TinkerPhu.
