Help modifying a Github cloned project
I am very new with Platfomio and I want to upload to a NODEMCU a cloned project from Github after making some changes.
If I download the ZIP file and open the project, I get a lot of errors when building, so I cloned the project using the “Clone Git Project” option and it builds and upload with no issues, but if I make any change, save the file, build and then upload to NODEMCU the changes don´t apply and the uploaded firmware is always the original.
Can anyone give me a hint by telling me what I am doing wrong? Or what I should do and I am not doing?
Thanks a lot in advance!
Regards.
When you change a source file, do you see it being recompiled when you press the compile button / execute pio run? What change did you do and what result should it have?
I click on “Clone Git Ptoject” then paste the URL. (GitHub - sidoh/esp8266_milight_hub: Replacement for a Milight/LimitlessLED hub hosted on an ESP8266)
Then I click on the alien head on the left and then on Build, and everything seems to run ok
Then I click un upload and the bin file is uploaded to the NODEMCU.
I run it and I use it with no issues.
Then I look for a file esp8266_milight_hub\web\src\index.html and modify the title of this html file and save it.
Then I click on build again and then upload, but the uploaded .bin is the same as before without the change. (the title of the html is the original)
Well how this project does it is a little bit more compilacted, a pre extra script triggers the invocation of npm to build stuff which then results in a changed dist/index.html.gz.h GZIPed file included by the server.
Can you do a pio run -t clean and a pio run -v from the shell and upload the logs of that https://pastebin.com/. Which operating system are you using?
I am in Win10
Log is so long that I cant get it all.
Is there any way to save it into a file or some to get it after building?
Yes that’s why I needed to know your OS. Do:
pio run -v > comple_log.txt 2>&1
and upload the compile_log.txt to pastebin.
Try Upload File System Image since you want to update the SPIFFS data… :wink:
See post above, a .cpp file include a header file which encodes the GZIP file. No SPIFFS, though it was also my first guess.
Hi again…
The complete generated log is 9.5kb so I can´t paste it on pastebin, so I put in my dropbox for you to see it:
Let me know if you can get it…
Hey! I installed node.js that wasn´t on my system and now works!
Thanks @maxgerhardt for your support!
Regards.
Well, that’s annoying… the main code uses SPIFFS, so that must be for other stuff. That particular one is a bit too convoluted in my opinion… maybe the author was trying to avoid the two step upload process?
