Helpme. i cant debug, Thanks you.
xPack OpenOCD, x86_64 Open On-Chip Debugger 0.10.0+dev-00378-ge5be992df (2020-06-26-09:29)
Licensed under GNU GPL v2
For bug reports, read
srst_only separate srst_gates_jtag srst_open_drain connect_deassert_srst
Info : tcl server disabled
Info : telnet server disabled
Info : STLINK V2J37S7 (API v2) VID:PID 0483:3748
Info : Target voltage: 3.251459
Info : clock speed 800 kHz
Info : starting gdb server for stm8s.cpu on pipe
Info : accepting ‘gdb’ connection from pipe
warning: Can not parse XML target description; XML support was disabled at compile time
undefined debug reason 8 - target needs reset
0x000082a9 in ?? ()
Unable to access DWARF register number 8
