It looks as if CoDrone is using a custom Arduino core. See package that’s downloaded as part of the Arduino board installation: http://www.robolink.com/wp-content/uploads/2016/07/RokitSmartInventor_1.0.3.zip
Indeed, as @manuelbl and @pfeerick noted, a different Arduino core seems to be used, right? You also installed this Arduino core and selected the “SmartInventor” board for compilation?
Anyway, try the following:
- Download the RokitSmartInventor ZIP file for above and extract it
- Copy the “cores\atmega32” folder as “Rokit” into
C:\Users\<user>\.platformio\packages\framework-arduinoavr\cores
- copy all folders from “variants” into
C:\Users\<user>\.platformio\packages\framework-arduinoavr\variants
- use the following
platformio.ini
[env:ATmega32]
board = ATmega32
platform = atmelavr
board_build.core = Rokit
board_build.variant = SmartInventor
CoDrone
- compile and observe
DATA: [===== ] 47.0% (used 963 bytes from 2048 bytes)
PROGRAM: [== ] 24.4% (used 7868 bytes from 32256 bytes)
With that the new Arduino core is successfully hacked in PlatformIO’s framework-arduinoavr
package, and we can also see that the compiled binary size has increased, though it’s still not at the level of the Arduino IDE. But now we are at least using the correct core and variant, which might help…
Edit: I also notice that SmartInventor-mega32_v2.build.f_cpu=7372800L
line in the boards.txt, so if you are using that variant, you need to additionally add
board_build.f_cpu = 7372800L
Hello, thank you very much for helping me get this working. I really appreciate it.
Here is my code:
//#include <Arduino.h>
#include <CoDrone.h>
//#include <EEPROM.h>
CoDrone.begin(115200);
CoDrone.pair(Nearest);
CoDrone.takeoff(); //goes up and hovers for 3 seconds
CoDrone.hover(10); //hovers for an additional 2 seconds
CoDrone.land(); //lands the CoDrone
void loop()
byte bt8 = digitalRead(18);
byte bt4 = digitalRead( 14);
byte bt1 = digitalRead(11);
if(bt1 && bt4 &&!bt8)
CoDrone.emergencyStop();
Do I need to include the “Arduino.h”. I don’t think so.
Here is my compilation output:
Processing ATmega32 (platform: atmelavr; framework: arduino; board: ATmega32)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/ATmega32.html
PLATFORM: Atmel AVR 1.15.0 > ATmega32
HARDWARE: ATMEGA32 16MHz, 2KB RAM, 31.50KB Flash
PACKAGES: toolchain-atmelavr 1.50400.190710 (5.4.0), framework-arduinoavr 4.1.1
Found 1 compatible libraries
|-- <CoDrone> 2.1.1
Compiling .pio\build\ATmega32\src\main.cpp.o
Compiling .pio\build\ATmega32\lib871\CoDrone_ID909\CoDrone.cpp.o
Compiling .pio\build\ATmega32\lib871\CoDrone_ID909\CoDrone_led.cpp.o
Compiling .pio\build\ATmega32\lib871\CoDrone_ID909\CoDrone_request.cpp.o
In file included from src\main.cpp:2:0:
C:\Users\DDS\.platformio\lib\CoDrone_ID909/CoDrone.h:9:21: fatal error: Arduino.h: No such file or directory
* Looking for Arduino.h dependency? Check our library registry!
* CLI > platformio lib search "header:Arduino.h"
* Web > https://platformio.org/lib/search?query=header:Arduino.h
compilation terminated.
*** [.pio\build\ATmega32\src\main.cpp.o] Error 1
In file included from C:\Users\DDS\.platformio\lib\CoDrone_ID909\CoDrone.cpp:7:0:
C:\Users\DDS\.platformio\lib\CoDrone_ID909\CoDrone.h:9:21: fatal error: Arduino.h: No such file or directory
*** [.pio\build\ATmega32\lib871\CoDrone_ID909\CoDrone.cpp.o] Error 1
In file included from C:\Users\DDS\.platformio\lib\CoDrone_ID909\CoDrone_request.cpp:1:0:
*** [.pio\build\ATmega32\lib871\CoDrone_ID909\CoDrone_request.cpp.o] Error 1
In file included from C:\Users\DDS\.platformio\lib\CoDrone_ID909\CoDrone_led.cpp:1:0:
*** [.pio\build\ATmega32\lib871\CoDrone_ID909\CoDrone_led.cpp.o] Error 1
========================================================================= [ERROR] Took 1.81 seconds =========================================================================
The terminal process terminated with exit code: 1
In directory I have:
C:\Users\DDS\.platformio\packages\framework-arduinoavr\cores\Rokit
atmega16
atmega32
atmega128
C:\Users\DDS\.platformio\packages\framework-arduinoavr\variants
SmartInventor
Ardu-X100
Ardu-X200
Hopefully this can help use find what we are missing.
How do I “add” board_build.f_cpu _ 7372800L line?
Thank you very much.
Joe
Here is my platformio.ini file:
[env:ATmega32]
board = ATmega32
platform = atmelavr
CoDrone
Literally just add
to your platformio.ini
… just like the core and variant parameters.
Yes… as soon as you use setup()
and loop()
(among other things) you need to #include <Arduino.h>
I’m not sure why it’s not being found when CoDrone.h
etc. try to include it as well though.
No, your Arduino core is not installed properly, you must not have the three atmegaX
folders there, but the contents of atmega32
must be inside the cores\Rokit
folder, as I have written above. It can’t find the Arduino.h
(and the entire core) this way.
Hello, thanks to everyone helping me get this working.
How does this look?
[env:ATmega32]
board = ATmega32
platform = atmelavr
CoDrone
Will give it a try.
Joe
Processing ATmega32 (framework: arduino; board: ATmega32; platform: atmelavr)
Looking for board_build.f_cpu library in registry
Warning! Library `{'requirements': None, 'name': 'board_build.f_cpu '}` has not been found in PlatformIO Registry.
You can ignore this message, if `{'requirements': None, 'name': 'board_build.f_cpu '}` is a built-in library (included in framework, SDK). E.g., SPI, Wire, etc.
|-- <CoDrone> 2.1.1
src\main.cpp:1:21: fatal error: Arduino.h: No such file or directory
========================================================================= [ERROR] Took 1.74 seconds =========================================================================
Hello, I’ve made the suggested changes and unable to get a good path to the header files. Any ideas?
I’ll keep trying.
Not sure how to update include path but will work on it. Thank you
I updated the ini file to be:
[env:ATmega32]
board = ATmega32
platform = atmelavr
CoDrone
It works!!!
Thank you everyone!
Thank you for not giving up on me and letting me squander in my mess.
Thank for the terrific technical support.
Joe
