HELP! 'avr-gcc-ar' is not recognized as an internal or external command
I’m running a VS Code on Win 10 desktop, installed latest version of pio.
When I was trying to build an example blink project for Arduino UNO, these error messages pop up!
‘avr-gcc-ar’ is not recognized as an internal or external command,
operable program or batch file.
*** [.pioenvs\uno\libFrameworkArduinoVariant.a] Error 1
Compiling .pioenvs\uno\FrameworkArduino\HardwareSerial.o
’avr-g++’ is not recognized as an internal or external command,
*** [.pioenvs\uno\src\main.o] Error 1
*** [.pioenvs\uno\FrameworkArduino\CDC.o] Error 1
*** [.pioenvs\uno\FrameworkArduino\HardwareSerial.o] Error 1
=================================================== [ERROR] Took 1.27 seconds ===================================================
And green squiggle under #include “Arduino.h”
What should I do to solve this , I’m totally new in this, please help me!
Any help would be appreciated.
Thank you.
Could you try to remove %HOME_DIR%\.platformio and start build again?
I had the same issue and I can confirm this worked for me
