I’m experiencing an odd issue with a Nucleo L432KC devboard from ST. When I start the IWDG using the following code:
IWDG_HandleTypeDef IwdgHandle;
IwdgHandle.Instance = IWDG;
IwdgHandle.Init.Prescaler = IWDG_PRESCALER_256;
IwdgHandle.Init.Reload = 30 * 125;
// 30 sec * 125 watchdog pulses per sec using the LSI frequency of ~32kHz and prescaler 256
and then try to “pet” the watchdog using the following:
HAL_IWDG_Refresh(&IwdgHandle); // resets the IWDG counter back to 0
The device immediately resets and the RCC_FLAG_IWDGRST
is set, indicating the reset was due to the watchdog timeout.
This issue using the same code worked perfectly on a Nucleo L152RE (the only difference is the dependencies now are for the L4xx series instead of L1xx)
Any ideas on why this reset is occuring?
