I had a test project using EspMQTTClient as a library module (To set up WiFi and MQTT). This compiled and worked fine until I did the upgrades. Now the compiler can’t find various include files (e.g. Update.h included from ArduinoOTA). The files are loaded (e.g.in .platformio/packages/framework-arduinoespressif32/libraries) and I can skip to the next problem by specifically including it in platformio.ini build_flags. I was expecting LDF to have sorted this out. The platformio.ini file contains:
[env:wemos_d1_mini32]
board = wemos_d1_mini32
;platform_packages =
; framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git#2.0.9
bblanchon/ArduinoJson@^6.19.4
knolleary/PubSubClient@^2.8
plapointe6/EspMQTTClient@^1.13.3
JAndrassy/ArduinoOTA
spacehuhn/SimpleMap@^1.0.0
ESP Async WebServer
ayushsharma82/AsyncElegantOTA @ ^2.2.5
daven006/TASKINFO
daven006/iotConfig
daven006/settings @ ^1.0.2
daven006/Led
build_src_filter = +<*> -<Temp files/>
-Wl,-Map,output.map
-I ../../include
-DCORE_DEBUG_LEVEL=5
-I C:/Users/User/.platformio/packages/framework-arduinoespressif32/libraries/Update/src
Despite a week of looking I’m not clear how how to set up compatible versions of the IDE and libraries.
Thanks in advance for any pointers…
All of these libs either don’t have their version pinned or, via ^
, allow arbitrary change in minor version (the z in x.y.z).
You can always pin these versions with a @<version>
Same for the platform version. If you want to roll back to an older platform version (and with it an older Arduino-core version), look at the released versions https://github.com/platformio/platform-espressif32/releases and how to use them.
And finally, instead of
really try using the right lib_ldf_mode that makes all libraries recognize their dependencies correctly – the -I
flag is really crude workaround for this. You can always do a project tasks → Advanced → Verbose Build to see the full dependency graph and notice any weirdness (things that are missing).
Having set platformio to
framework = framework-arduinoespressif32
and removed the extraneous includes
I now get
CONFIGURATION: Redirecting...
PLATFORM: Espressif 32 (5.3.0) > WEMOS D1 MINI ESP32
- tool-esptoolpy @ 1.40400.0 (4.4.0)
Error: This board doesn’t support framework-arduinoespressif32 framework!
The board wemos_d1_mini32 worked before and seems to be fairly standard so what am I missing??
There is no such possible value.
You mean framework = arduino
