Hi, I’m trying to setup CI on GitLab for a platformio project.
While the compilation seems to go through, PlatformIO fails because it can’t find the csv with the partition table which is there.
This is the project structure:
- platformio.ini
- .gitlab-ci.yml
- mypartitions.csv
- src/mymain.cpp
platformio.ini:
[env:esp32doit-devkit-v1]
board = esp32doit-devkit-v1
board_build.partitions = mypartitions.csv
.gitlab-ci.yml
image: python:2.
stages:
- test
before_script:
- “pip install -U platformio”
job:
stage: test
script: “platformio ci -C platformio.ini”
variables:
PLATFORMIO_CI_SRC: “src/mymain.cpp”
Build error:
Compiling .pioenvs/esp32doit-devkit-v1/src/mymain.cpp.o
*** [.pioenvs/esp32doit-devkit-v1/partitions.bin] Source src/mypartitions.csv' not found, needed by target
.pioenvs/esp32doit-devkit-v1/partitions.bin’.
========================== [ERROR] Took 31.62 seconds ==========================
ERROR: Job failed: exit code 1
