Getting terminal to work with Arduino Gigi
I just tried an Arduino Gigi board and have been successful in loading a blink sketch in Platform IO M7 but have not been able to get the terminal to print a line using Serial.println(“start”); The program runs and blinks the LED but terminal will not print. Any suggestions?
Program is as follows:
// put function declarations here:
  delay(3000);
  Serial.println("start M7");
  pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH);  // turn the LED on (HIGH is the voltage level)
  delay(1000);                      // wait for a second
  digitalWrite(LED_BUILTIN, LOW);   // turn the LED off by making the voltage LOW
  delay(1000);
INI file :
 env:giga_r1_m7]
platform = ststm32
board = giga_r1_m7
monitor_port = COM10
Can you remove monitor_port from the platformio.ini?
You did use the project task “Monitor” to open the serial monitor?
I have tried that with and w/o monitor_port and monitor_speed. I have used project task"Monitor" and the Icon at the bottom to start the terminal. When I use the Arduino IDE the program works and prints as it should. Of course I would prefer to use PlatformIO to do the programming. Thanks, for your reply. John
It may just be the case that opening the serial monitor doesn’t restart the sketch. (likely done via some 1200bps reset or monitor DTR/RTS signaling?)
What happens if you continously print stuff? Does the “Upload + Monitor” task show it then?
  delay(3000);
  Serial.println("Blinky!");
  delay(1000);
Well , that seemed to work… The start M7 never printed but the Blinky! does print. What do you think is going on? Processor too fast and it miss the first print in setup, or the DTS/RTS signaling not initiating correctly?
Then there’s probably no “reset on serial monitor open” happening. As said, I’m not sure how this is supposed to work, but there is a standard piece of code against that:
// While no USB serial monitor connection is established, do nothing.
while(!Serial) { delay(1); }
So, if you use code like
  delay(1000);
You shoud see the serial output “from the beginning”.
If I run :
int first = 0;
delay(3000);
Serial.println(“start M7”);
Serial.println(“Blinky!”);
first = first + 1;
Serial.println(first);
delay(1000);
The terminal take 3 tries before it starts to print. FYO
