I got it working but here’s what I found out.
I failed to get an ATtiny3226 to work with the SD library. This seems a common problem in some of the threads I read.
I ended up using an Arduino ProMini - this has a ATMEGA328 processor - just like an Arduino Uno.
This has 32K Flash and 2K SRAM.
I had to force PlatfirmIO to use a working version of SD.h by adding it as a library under the PIO Home | Libraries menu - this loaded the line below into my platformio.ini
lib_deps = arduino-libraries/SD@^1.3.0
Even so the small test sketches from Arduino examples took a bunch of RAM and Flash - see the compile output.
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/pro16MHzatmega328.html
PLATFORM: Atmel AVR (5.1.0) > Arduino Pro or Pro Mini ATmega328 (5V, 16 MHz)
HARDWARE: ATMEGA328P 16MHz, 2KB RAM, 30KB Flash
DEBUG: Current (avr-stub) External (avr-stub, simavr)
- framework-arduino-avr @ 5.2.0
- toolchain-atmelavr @ 1.70300.191015 (7.3.0)
Found 6 compatible libraries
|-- SD @ 1.3.0
|-- SPI @ 1.0
Checking size .pio/build/pro16MHzatmega328/firmware.elf
RAM: [===== ] 46.3% (used 949 bytes from 2048 bytes)
Flash: [===== ] 47.0% (used 14434 bytes from 30720 bytes)
I still need a RTC and still want it to be battery powered so I think I’ll use a 3.3v ProMini at 8MHz and an SD card reader that works directly to 3.3v (mine had a level shifter in the way which I read hogs the SPI bus).
