Get erro when building
I need help!
I’m working in telemetry project based on a Arduino ESP32. When I’m trying to build the project, I get the erro:
c:/users/breno/.platformio/packages/toolchain-xtensa-esp32/bin/…/lib/gcc/xtensa-esp32-elf/8.4.0/…/…/…/…/xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32dev\src\dataserver.cpp.o:(.data.urlHandlerList+0x14): undefined reference to `handlerControl(UrlHandlerParam*)’
*** [.pio\build\esp32dev\firmware.elf] Error 1
I put all sources of my project on Github: Freematics/firmware_v5/telelogger at master · stanleyhuangyc/Freematics · GitHub
Heres all the log when building
Processing esp32dev (platform: https://github.com/platformio/platform-espressif32.git#feature/arduino-upstream; board: esp32dev; framework: arduino)
* Adding toolchain toolchain-riscv32-esp with version 8.4.0+2021r2
* Adding toolchain toolchain-xtensa-esp32 with version 8.4.0+2021r2
* Adding toolchain toolchain-xtensa-esp32s2 with version 8.4.0+2021r2
PLATFORM: Espressif 32 (3.3.1+sha.3784198) > Espressif ESP32 Dev Module
HARDWARE: ESP32 160MHz, 320KB RAM, 4MB Flash
 - framework-arduinoespressif32 @ 0.0.0+sha.caef400
 - tool-esptoolpy @ 1.30100.210531 (3.1.0)
 - toolchain-xtensa-esp32 @ 8.4.0+2021r2
Converting telelogger.ino
Found 36 compatible libraries
|-- FreematicsPlus
|   |-- WiFi @ 2.0.0
|   |-- SPI @ 2.0.0
|-- FS @ 2.0.0
|-- httpd
|-- SD @ 2.0.0
|   |-- FS @ 2.0.0
|   |-- SPI @ 2.0.0
|-- SPI @ 2.0.0
|-- SPIFFS @ 2.0.0
|   |-- FS @ 2.0.0
|-- WiFi @ 2.0.0
|-- FreematicsOLED
|   |-- Wire @ 2.0.0
Compiling .pio\build\esp32dev\src\dataserver.cpp.o
Compiling .pio\build\esp32dev\src\teleclient.cpp.o
Compiling .pio\build\esp32dev\src\telelogger.ino.cpp.o
Compiling .pio\build\esp32dev\src\telemesh.cpp.o
Compiling .pio\build\esp32dev\libc77\WiFi\WiFi.cpp.o
Compiling .pio\build\esp32dev\libc77\WiFi\WiFiAP.cpp.o
Compiling .pio\build\esp32dev\libc77\WiFi\WiFiClient.cpp.o
Compiling .pio\build\esp32dev\libc77\WiFi\WiFiGeneric.cpp.o
Compiling .pio\build\esp32dev\libc77\WiFi\WiFiMulti.cpp.o
Compiling .pio\build\esp32dev\libc77\WiFi\WiFiSTA.cpp.o
Compiling .pio\build\esp32dev\libc77\WiFi\WiFiScan.cpp.o
Compiling .pio\build\esp32dev\libc77\WiFi\WiFiServer.cpp.o
Compiling .pio\build\esp32dev\libc77\WiFi\WiFiUdp.cpp.o
Compiling .pio\build\esp32dev\libf81\SPI\SPI.cpp.o
Compiling .pio\build\esp32dev\libd89\FreematicsPlus\FreematicsGPS.cpp.o
Compiling .pio\build\esp32dev\libd89\FreematicsPlus\FreematicsMEMS.cpp.o
Archiving .pio\build\esp32dev\libf81\libSPI.a
Compiling .pio\build\esp32dev\libd89\FreematicsPlus\FreematicsNetwork.cpp.o
Compiling .pio\build\esp32dev\libd89\FreematicsPlus\FreematicsOBD.cpp.o
Compiling .pio\build\esp32dev\libd89\FreematicsPlus\FreematicsPlus.cpp.o
Compiling .pio\build\esp32dev\libd89\FreematicsPlus\utility\ICM_20948_C.c.o
Compiling .pio\build\esp32dev\libd89\FreematicsPlus\utility\ble_spp_server.c.o
Archiving .pio\build\esp32dev\libc77\libWiFi.a
Compiling .pio\build\esp32dev\lib9b9\FS\FS.cpp.o
Compiling .pio\build\esp32dev\lib9b9\FS\vfs_api.cpp.o
Compiling .pio\build\esp32dev\lib2a0\httpd\httpd.c.o
Compiling .pio\build\esp32dev\lib2a0\httpd\httpjson.c.o
Compiling .pio\build\esp32dev\lib2a0\httpd\httppil.c.o
Compiling .pio\build\esp32dev\lib508\SD\SD.cpp.o
C:/Users/breno/Downloads/Freematics-master/libraries/httpd/httpd.c:107:23: warning: initialization discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
 char* defaultPages[]={"index.htm","index.html","default.htm","main.xul"};
C:/Users/breno/Downloads/Freematics-master/libraries/httpd/httpd.c:107:35: warning: initialization discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
C:/Users/breno/Downloads/Freematics-master/libraries/httpd/httpd.c:107:48: warning: initialization discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
C:/Users/breno/Downloads/Freematics-master/libraries/httpd/httpd.c:107:62: warning: initialization discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
Compiling .pio\build\esp32dev\lib508\SD\sd_diskio.cpp.o
Compiling .pio\build\esp32dev\lib508\SD\sd_diskio_crc.c.o
Compiling .pio\build\esp32dev\lib5d2\SPIFFS\SPIFFS.cpp.o
Compiling .pio\build\esp32dev\liba0f\Wire\Wire.cpp.o
Compiling .pio\build\esp32dev\lib531\FreematicsOLED\FreematicsOLED.cpp.o
Archiving .pio\build\esp32dev\lib9b9\libFS.a
Archiving .pio\build\esp32dev\libd89\libFreematicsPlus.a
Archiving .pio\build\esp32dev\lib2a0\libhttpd.a
Archiving .pio\build\esp32dev\lib508\libSD.a
Archiving .pio\build\esp32dev\liba0f\libWire.a
Archiving .pio\build\esp32dev\lib5d2\libSPIFFS.a
Archiving .pio\build\esp32dev\lib531\libFreematicsOLED.a
Linking .pio\build\esp32dev\firmware.elf
c:/users/breno/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32dev\src\dataserver.cpp.o:(.data.urlHandlerList+0x14): undefined reference to `handlerControl(UrlHandlerParam*)'
Thanks
Big red flag: I would not recommend using this outdated branch at all – it seems you have that from an old recommendation on how to use Arduino-ESP32 2.x.x when offical support wasn’t yet out. This “upstream” branch is 140 commits behind master. Set platform = espressif32 and use pio platform update espressif32 in the CLI accordingly to get the 2.0.3 core.
In regards to the actual
error: Looking at Search · handlerControl · GitHub I see that function is implemented in the projects ESPRIT/garden_controller and ESPRIT/gps_logger, but in the projects firmware_v5/telelogger and firmware_v5/datalogger the function is only referenced but never implemented.
Continuing the discussion from Get erro when building:
Thanks.
But, an error show when I am trying to upload.
c:/users/breno/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32dev\libFrameworkArduino.a(main.cpp.o):(.literal._Z8loopTaskPv+0x8): undefined reference to `setup()'
c:/users/breno/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32dev\libFrameworkArduino.a(main.cpp.o):(.literal._Z8loopTaskPv+0xc): undefined reference to `loop()'
c:/users/breno/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32dev\libFrameworkArduino.a(main.cpp.o): in function `loopTask(void*)':
C:/Users/breno/.platformio/packages/framework-arduinoespressif32@src-afacabbe58d012c05a6ee24950dc6ba1/cores/esp32/main.cpp:42: undefined reference to `setup()'
c:/users/breno/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:/Users/breno/.platformio/packages/framework-arduinoespressif32@src-afacabbe58d012c05a6ee24950dc6ba1/cores/esp32/main.cpp:48: undefined reference to `loop()'
Can you update the repo with the newest files so I can check against that?
I am a newbie at this. So, I don’t know if the information bellow help.
platform = https://github.com/platformio/platform-espressif32.git#feature/arduino-upstream
platform_packages = platformio/framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git#2.0.2
;build_flags = -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue
board=esp32dev
board_build.f_cpu = 160000000L
[platformio]
src_dir=.
[env]
lib_extra_dirs=../../libraries
Well for faithfull reproduction I’d need all the files. I meant that Freematics/firmware_v5/telelogger at master · stanleyhuangyc/Freematics · GitHub is still not updated.
Sorry for the delay in replying.
The docs are here (telelogger_brtostes/telelogger at main · brtostes/telelogger_brtostes · GitHub).
